Question about MGE Evolution 2000 Rt2U Ups W/ 6 Outlets - 81712 UPS System
My ups switches on then shows me an internal fault. when i go into the menu it says faulty internal fan. i have checked and all 3 fans are working fine.
Apc smart ups rt 10000 internal fault, what to look for?
you should check the inverter and the charger boards as well.
Mainly IGBTs and drivers (IGBT drivers).
better locate the fault and replace the defective board
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
My cannon machine shows error 805 when i start the machine pls solve my problem
the internal fan is not working and that is the code for it. there is a fan inside with 3-4 wire on it one wire on the fan tells the machine that it is working if the fan is working then the fan has a fault on this part of the motor it can wear out as it is in contact with the fan inside. also check the wires to the plug sometimes if it gets banged about it can come loose, fan located in the main Left Door. hope fully it is just this and not the pcm board at fault as that can mean that there is a real problem could be the board power board or the switches for the draws. hope this helps you.
Sep 19, 2013 | Canon Service Manual For Ir 400
Carrier Performance Boost 80 has a status light flashing on the furnace, 3 times fast followed by 3 times slow. What does that mean?
this indicates fault 33, on inside of access panel will tell you faulty switch. i believe off top of my head is pressure switch open, this a safety switch to verify that inducer fan is working, several things besides a failed part can cuase this, there is a rubber hose going from the inducer fan houseing to the safety pressure switch, remove hose from fan housing and run a small stick ,wire or torch tip cleaner, down the acces port, calcium builds up inside the port and blocks the sampling of pressure, reassemble and try it, if this works add it to yearly maintenance could need new switch or inducer fan motor, these need to be replaced by a tech, also birds can block flue pipe
Feb 02, 2011 | Heating & Cooling
Volkswagon POLO 2001 Manual Problem: thermo fan not working. Hi all, I have since ordered and replaced the fan with a another fan and the fan still does not work!! Could it be the fuse? Initial...
CHECK TO SEE IF POWER GOING TO COOLANT FAN AND COOLANT FAN THERMO SWITCH.THERMO SWITCH LOCATED BOTTOM OF RADIATOR ON THE LEFT HAND SIDE.IF POWER GOING TO THERMO SWITCH THEN SWITCH IS FAULTY.IF NO POWER GOING TO THERMO SWITCH OR COOLING FAN.CHECK LARGE FAN FUSE IN THE ENGINE COMPARTMENT AND YOU HAVE FUSE 16 IN FUSE HOLDER.IF FUSES GOOD YOU HAVE SHORT IN THE FAN WIRE OR FAULTY FAN CONTROL MODULE.SHAKE FAN WIRES IF FAN WORKS PROBLEM IN THE FAN WIRES YOU HAVE A SHORT IN THE WIRES..
Jan 12, 2011 | 1996 Volkswagen Golf
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
2006 honda Odyssey front fan quit
I'm not sure where you are based, but with most new vehicles there is a 3 year or 60,000 mile warranty, so it should be covered under that if there is a fault. I recommend taking it to the dealer if the warranty is still current, otherwise if it is not you could check through the fuses to make sure it's not just a blown fuse, maybe check the wiring to the fan motor under the dash to make sure it's still plugged in and not damaged, and (with the key on and the heater fan switched on) check for power to the fan motor with a testlight. If there is power there then the fan motor is faulty, if not then there is fault with the control system, but that is probably about as far as you could go at home. Obviously if the fan is faulty you could replace it yourself if it's easily accessible. Any further faults would need a Honda dealer or good auto electrician to diagnose.
Hope this helps,
Mark.
Nov 02, 2008 | 2006 Honda Odyssey
Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Apr 15, 2008 | Epson EMP-54 Multimedia Projector
Problem of motherboard
Could be a power supply fault, motherboard fault, or fan fault. Many new motherboards will not power up if the fan doesn't rotate, to prevent the processor getting fried.
Dec 06, 2007 | Intel D101GGC Motherboard
MGE Evolution 2000 Rt2U Ups W/ 6 Outlets - 81712 UPS System Logo
32 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
