Question about ASUS P5VD2-MX SE Motherboard
Where do wires go?
On the corner of the asus p5vd2-mx se motherboard there are pins which are for power switch/reset/led and so on.In what position do they go.Got the main fan one working.Would these wires also stop the monitor being in standby mode all the time.Hope this is all the info you require to help me.
  • dave8 Oct 07, 2007
    which wire would it be that leaves monitor on standyby
  • 661 Answers
There is a pin-out for the front panel interface in the user manual, There are pins for Power button, reset, HDD activity, and for a few other functions THIS IS NOT WHERE THE FANS PLUG IN. The fans connect to the Fan connectors, there are usually 2/3 on the board, 1 near the CPU, 1 near the memory and 1 usually close to the IDE/ SATA connectors
Posted on Oct 07, 2007
  • Gareth Cockram
    Gareth Cockram Oct 07, 2007
    there is a pair which would be for a standby buttn, however you just leave that pair open (don,t short together)
    the entire pin out is fully described in the manual.
  • Gareth Cockram
    Them monitor has it's own standby mode when it is not in use... (Not receiving a live input)
    This is not to be confused with the computer's standby mode.
Manual needed
Paul,
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/
Download> Select OS (I just clicked on WinXP) > Click on the + sign next to Manual (5)
Version 1877
P4VP-MX user's manual English version E1877
2.5 MBytes
Click on the blue -> Global
Or copy this,
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4vp-mx/e1877_p4vp-mx.pdf
Paste it in your address bar, and press the Enter key.
(May take up to 30 seconds before the first page comes up)
Page 17 - Motherboard Layout
(PDF file page. 1-7 for the actual manual page)
Page 28 - Front Panel Audio Connector (1-18)
Page 30 - USB Header (10-1 pin USB56) (1-20)
Page 32 - System panel connector (10-1 pin PANEL1) (1-22)
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main cables, (Wires), go to, is the Front Panel header.
Motherboard as installed in computer case;
Processor to the top, Ram Memory slots to the right, white PCI slots to the bottom;
The Front Panel header is located at the Bottom/Right corner.
PANEL1.
Two rows of pins.
(To the left of it is the front panel USB header. USB56. Looks very similar)
Doesn't show numbering for the pins. (Contact pins)
I'm going to number them for easier orientation
The pins across the TOP are numbered ODD.
Starting on the LEFT side going towards the Right;
Pins 1, 3, 5, and 7. There is NO Pin 9.
The pins across the BOTTOM are numbered EVEN.
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the LED is dim when the computer is on, switch the wires around.
B) Pins 5 and 7 are for the Power On switch.
C) Pins 2 and 4 are for the HarDDrive activity LED (Light)
May be marked on the wires as HDD, or IDE.
Pin 2 is for the Positive ( + ) wire.
If the harddrive activity LED is dim when the harddrive is active, switch the wires around.
D) Pins 6 and 8 are for a Reset switch, IF a Reset switch is used.
E) Pin 10 is N/C
Not Connected. (Probably a +5 Volt point for the factory to use)
Have problems downloading, or saving the PDF manual, post back in a Comment.
For additional questions post back in a Comment.
Regards,
joecoolvette
[Motherboard chipset;
Northbridge -> VIA VT8751A (Also known as VIA P4M266A)
Southbridge -> VIA VT8235
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Socket_478
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[CPU = Central Processing Unit. Another term used is Microprocessor, or simply -> Processor, for short ]
Jul 09, 2012 | ASUS Computers & Internet
I have not sound with vista my motherbord is p5vd2-mx
The drivers for ASUS P5VD2-MX Motherboard can be download from the Asus Official support site: -
Click here and follow these steps: -
1. Select Product - Motherboard
2. Select Series - Socket775
3. Select Model -
P5VD2-MX and click search, it would ask you for operating system (Vista 32 bit or 64 bit)
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Dec 31, 2010 | ASUS P5VD2-MX SE Motherboard
Have power but no display
Open cpu cover and Reconnect the RAM memory into the motherboard circuit.
Also check that RAM works fine.
If you have another ram try with it.
IF still same then you need to reset motherboard bios settings to default.
Check on motherboard you can fine 1 jumper near cmos cell set it into 2-3 pins then power up the motherbord 3 times then again put jumper in its original position.
Then all settings goes to defaults.
Feb 11, 2010 | ASUS P5VD2-MX SE Motherboard
HI!Could you write me the graphics cards that supports the asus p5vd2-mx se motherboard?because i have a problem with asus 8800gts.when i fit the card,the pc doesn't boot up,while when i fit my old...
Its is possible that the power supply isnt powering the graphics card, because of the power needed to run the fan and gpu. It is a more updated card than the 8600gt with more graphics processing speeds and capabilities, so it is possible you will have to buy a new power pack with more wattage.
Jan 28, 2010 | ASUS P5VD2-MX SE Motherboard
Inno3d 9800gt is it compatible with asus p5vd2-mx motherboards?
hELLO THERE:
I would contact the manufacture of the board and explain your problem with them to se if there is any compatability issues there but i really dont think there should be any problems
best regards mike
(usn retired)
Aug 04, 2009 | ASUS P5VD2-MX SE Motherboard
No Sound in Vista Ultimate Mobo P5VD2-MX SE
install sound driver from here
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5VD2-MX-SE-BIOS-0203.shtml
Mar 29, 2009 | ASUS P5VD2-MX SE Motherboard
REQURE MANUAL FOR ASUS P5VD2-MX SE MOTHERBOARD
I hope this is the manual that you're looking for.
please download it here. http://www.manualnguide.com/dl/9352/
Mar 21, 2009 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX SE sound driver
you can download the audio driver for your motherboard from some of the sites given below ...
http://www.nodevice.com/driver/P5VD2-MX/get34077.html
http://www.nodevice.com/driver/company/ASUS/Motherboard.html
http://www.driverstock.com/ASUS-P5VD2-MX-driver-download/6-9-10181/index.html
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Sep 02, 2008 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Jun 06, 2008 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX SE Motherboard Logo
178 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
