Elmo mo 1: I am using PPT 2013 and Windows 8. When I toggle from PPT to the ELMO, it works fine. When I toggle back, I get the extended Windows screen on the projected image. I then have to end the PPT show on my computer and open the show again. Even then, it comes up as a regular show versus the presenter view. I have to close it again and reopen it for the presenter view to appear on my computer and the ppt show to appear on the projected image. Please advise.
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: black and white projection
Hi there
First try another cable from the PC to the Projector.
The VGA / RGB Cable used from your PC to the Projector has a couple of very thin copper wires on the inside and they easily get damaged.
If this doesn't help then you should try another PC.
If that works then you'll know that it is the PC's card that is faulty.
If it doesn't work you'll have to get the Mainboard repaired or replaced , because the inputs on the Projector lies within the Mainboard.
Must warn you that a Mainboard replacement is a bit on the expensive side.
Posted on Mar 27, 2008
Marrie
  • 563 Answers
SOURCE: ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
Posted on May 13, 2008
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
Hokey Pokey Elmo sings and moves his hand and foot but stopped shaking and won't turn around in a circle. It worked fine then stopped working we changed the batteries and it worked a short time then quit...
Hi ms_debbie13
    How to Activate
  1. This plush, shiny red Elmo is standing with his arms up above his head. One foot is lifted slightly off the floor and the other is on the floor. On that foot, there is a swivel allowing Elmo to turn, the battery door and the on/off switch. Turn Elmo on and stand him upright then squeeze his left hand to begin his song.
    Elmo really moves his right arm and leg in time with the song, and also turns in a circle. When the song is done Elmo says, "Whew.. that was fun! Elmo's pooped!"
  2. Alternative Mode
  3. The alternative mode is Elmo trying to keep up as the music keeps getting faster. If Elmo falls over he will say, "Woops!" and then he will thank you when you set him back upright.
Jan 30, 2011 | Toys
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
My ELMO works when using the computer and the DVD player. When it is set to use the ELMO projector it keeps blinking off and on with the projector message no input RGB1 then blinks back to what the ELMO...
Depending upon which model you have, this can be a mechanical switch problem or an electronic one. Can you please update this with the model so I can provide more info?
Thanks,
Dan
Sep 29, 2010 | Computers & Internet
What size tray doe the Elmo TRV-35H use? What mfg is comparable?
It uses a standard 80 slide Kodak Carousel or comparable tray. Transvue works the best. Sometimes I can coax the Elmo to use a 140 slide tray, but the slides sometimes jam.
Sep 17, 2009 | Elmo Projectors TRV-35H Slide Projector
Elmo will not turn on, batteries are new
THE SENSOR IN HIM HAS MOVED.FEEL AROUND FOR IT THEN PUSH IT BACK INTO PLACE
Jul 15, 2009 | Gund Sesame Street: Elmo 25" Plush Doll by
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
14 people viewed this question
jasbo
jasbo
