Question about Aqua Brass Deckmount 5 pc tub set with separate diverter and hand shower AQUA BRASS 24
Aquabrass tub drain control lever cover separated from nut
AquaBrass Prestige Collection from year 2000 70188BN, 70197BNPG, 6200BN, 6463BNPG, 1031BNPG, 1405BN The cover for the drain control lever separated from the nut. Epoxy will not hold it; tried a welder who wants $45 for high temperature required to weld brass plus says the cover will discolor so will have to be replated. Aqua brass ignores me, dealer says they never made a tub drain control assembly
    New Friend:
    Problem Solver:
  • 7 Answers
Lock tight red or stronger will bond it together . but forget remove it after
Posted on Nov 16, 2013
2 Suggested Answers
radar001
  • 1051 Answers
SOURCE: need replacement handle ( knob ) for Aquabrass Seville 6016
If you can't locate the replacement locally try replacements.com. They have a variety of hard to find replacement items.
Posted on Jan 14, 2010
Aquabrass tub drain control: cover separated from nut
Try using jb weld or another type of epoxy that is water proof. 100% silicone caulk may also be worth a try.
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Aquamaster aquabrass plastic knob broken
please send your coordinates to info@aquabrass.com they will gladly send you a replacement part for free
Oct 20, 2012 | Aqua Brass AquaBrass 12699 Aquamaster...
Why is there restricted water flow
It may be as simple as cleaning the aerator out. If that is not the case then you will need to disassemble the faucet and investigate.
Feb 06, 2011 | Aqua Brass AquaBrass 10317 1/2...
My volume control handle takes several rotations before shower finally stops dripping. Do I need a new handle and how would I replace it?
The splines are probably striped and the handle will need replacing. but it may be as simple as the handle set screw is lose.
http://www.aquabrass.com/sections/shower
Nine out of ten times these handles go bad when they get lose so if you buy a new one it will come with instillation instructions.
Jan 30, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
How do I remove the bottom of the vertical bar on Aquamaster 12699? I want to insert a new sliding bracket. Thanks
Piece (escutheon)agains't wall should pop away from wall and twist,need a little flat head screwdriver to pop away from wall-screw should be underneath
Jan 28, 2011 | Aqua Brass AquaBrass 12699 Aquamaster...
Drain in the close position the drain handle is not working
Remove the 2 screws on the drain cover in the bath tub to gain access. Drain plug should be connected to trip lever on drain cover probably using a cotter pin with ends bent to keep it on. Do not yet remove the cotter pin.
To know for sure if it is the trip lever broken, you can hold the trip lever down and tub will drain. If you let go, trip lever on cover returns to upright position and stops draining. You can also feel the spring tension stay on it when you press the trip lever down. Most likely, the drain trip lever (spring action) which is a part of the cover itself is broken.
First have ice pick, thin screwdriver, (even a large paper clip (or 2 for strength) bent straight may do) or anything small enough to go through same hole in drain assembly as cotter pin, while long enough to go across hole in bathtub to hold drain assembly up till you install new drain cover attaching it to assembly with same or new cotter pin.
Now unbend the cotter pin (sort of looks like a heavy duty metal bobby pin) ends using pliers. Using pliers pull cotter pin out while holding drain assembly so it will not fall back into tub wall.
Next secure assembly using the above ice pick or large paper clip while you take trip lever (which is the cover)
to hardware store, etc. to pick up generic tub trip lever.
CHANCES ARE THE ABOVE SOLVED PROBLEM, BUT IN CASE IT WAS NOT THE TRIP LEVER WHEN YOU TESTED USING THE METHOD ABOVE TO DIAGNOSE THEN BELOW IS HOW TO REMOVE ENTIRE TUB DRAIN ASSEMBLY
There is a metal stem with a threaded rod coming up in it with a nut on it, and on the end of this is a round metal weight looking much like a very small upside down can. you will not be able to see all this unless it is neccesary to remove entire drain assembly which you can then take it to a Home Depot or Lowes type store to replace. Most can be replaced with a generic tub drain.
Now to get the assembly out once you've removed the 2 screws gently work metal stem assembly up and out at a slight angle. You may have to move nut on assembly to shorten the length in order to get it to clear the tub. IMPORTANT! If so, 1st mark the position of the nut on the threaded rod so you can put it back in same position when reinstalled before lowering assembly all the way back into tub wall.
Apr 17, 2010 | Home
Need replacement handle ( knob ) for Aquabrass Seville 6016
Jan 14, 2010 | Aqua Brass AquaBrass 6018 Deckmount 4 pc...
Leaking faucet = Aquabrass Volare - how do I fix it?
depending on the age of this faucet, it may have just worn out,or is defective.for what it may cost in repairs just replace the faucet.
Jul 05, 2009 | Plumbing
How do I get the clutch to release from the transmission on a evo
All 1996 Model Year and newer vehicles
equipped with manual transaxles except Accents
, which have the "push" type clutch system. SERVICE PROCEDURE:
  • Drain the transaxle gear oil.
  • The reference photo to the right shows the clutch related components as viewed from outside the transaxle case.
75c260f.jpg Loosen the release lever nut and washer
Separate the release lever by removing the snap pin and clevis pin.
Separate the release lever from the fork shaft.
Loosen the bolts attached to the release cylinder and separate the release cylinder from the transaxle assembly (no need to open the clutch hydraulic system).
  • Remove the transaxle assembly after removing each bolt attached to the engine assembly.
  • Remove the clutch cover assembly. The release bearing is still attached.
To separate the release bearing from the clutch cover, rotate the release bearing to gain access to the bearing snap ring.
Mar 28, 2009 | 2003 Hyundai Santa Fe
Aqua Brass Deckmount 5 pc tub set with separate diverter and hand shower AQUA BRASS 24 Logo
Top Aqua Brass Home Experts
Donni Steen
Tom Chichester
Are you an Aqua Brass Home Expert? Answer questions, earn points and help others
