Question about Aqua Brass Deckmount 5 pc tub set with separate diverter and hand shower AQUA BRASS 24
Aquabrass tub drain control: cover separated from nut
AquaBrass Prestige Collection from year 2000 70188BN, 70197BNPG, 6200BN, 6463BNPG, 1031BNPG, 1405BN The cover for the drain control lever separated from the nut. Epoxy will not hold it; tried a welder who wants $45 for high temperature required to weld brass plus says the cover will discolor so will have to be replated. Aqua brass ignores me, dealer says they never made a tub drain control assembly
    New Friend:
  • 14 Answers
Try using jb weld or another type of epoxy that is water proof. 100% silicone caulk may also be worth a try.
Posted on Nov 16, 2013
2 Suggested Answers
radar001
  • 1051 Answers
SOURCE: need replacement handle ( knob ) for Aquabrass Seville 6016
If you can't locate the replacement locally try replacements.com. They have a variety of hard to find replacement items.
Posted on Jan 14, 2010
Aquabrass tub drain control lever cover separated from nut
lock tight red or stronger will bond it together . but forget remove it after
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Aquamaster aquabrass plastic knob broken
please send your coordinates to info@aquabrass.com they will gladly send you a replacement part for free
Oct 20, 2012 | Aqua Brass AquaBrass 12699 Aquamaster...
Why is there restricted water flow
It may be as simple as cleaning the aerator out. If that is not the case then you will need to disassemble the faucet and investigate.
Feb 06, 2011 | Aqua Brass AquaBrass 10317 1/2...
My volume control handle takes several rotations before shower finally stops dripping. Do I need a new handle and how would I replace it?
The splines are probably striped and the handle will need replacing. but it may be as simple as the handle set screw is lose.
http://www.aquabrass.com/sections/shower
Nine out of ten times these handles go bad when they get lose so if you buy a new one it will come with instillation instructions.
Jan 30, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
How do I remove the bottom of the vertical bar on Aquamaster 12699? I want to insert a new sliding bracket. Thanks
Piece (escutheon)agains't wall should pop away from wall and twist,need a little flat head screwdriver to pop away from wall-screw should be underneath
Jan 28, 2011 | Aqua Brass AquaBrass 12699 Aquamaster...
Need replacement handle ( knob ) for Aquabrass Seville 6016
Jan 14, 2010 | Aqua Brass AquaBrass 6018 Deckmount 4 pc...
Leaking faucet = Aquabrass Volare - how do I fix it?
depending on the age of this faucet, it may have just worn out,or is defective.for what it may cost in repairs just replace the faucet.
Jul 05, 2009 | Plumbing
My dishwasher will not drain it is a GE nautilus.
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Will not drain
Mar 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Aqua Brass Deckmount 5 pc tub set with separate diverter and hand shower AQUA BRASS 24 Logo
73 people viewed this question
Top Aqua Brass Home Experts
Donni Steen
Tom Chichester
Are you an Aqua Brass Home Expert? Answer questions, earn points and help others
