Question about Plumbing
How to add a heat zone
Adding a heat zone
  • 2,113 Answers
You can buy a zone valve at a plumbers supply. Get a 24 volt one with a 24 volt transformer and a thermostat. Place it in the circuit that feeds the zone that requires heating and it's own control
Posted on Nov 19, 2013
Honeywell how to
You don't say what kind of control panel you're trying to add this to, but I would guess a Vista 20 based on the symptoms. You cannot use a 4208U for this panel...what you need is a 4219, but even that may not work because Honeywell has changed the components without changing the part numbers, making the new expanders incompatible with older controls. You may need to upgrade to a Vista 20P.
Aug 26, 2014 | Ademco 4208u Universal 8 Zone Remote Point...
When i try to bring up google i get no site configured
Method 1: Try adding the website to trusted sites and check if he is able to access the websites
Security zones: adding or removing websites
http://windows.microsoft.com/en-US/windows7/Security-zones-adding-or-removing-websites
Method 2:I would suggest you to try the steps from the following link:
Cannot access some websites in Internet Explorer
http://support.microsoft.com/kb/967897
Dec 09, 2013 | google.com
We have radiant floor heating system ran with /wirsbo valves. One zone is not working..not heating at all. The valve seems to open up when thermostat is turned on but not heating room. Any suggestions?
Are you able to isolate the Zone?
If you are able to isolate the Zone, is there anyway you can bleed air out of the system?
1) turn off the other zones and see if this one starts to heat up,
if not. Try to bleed Air out of the main header until it gets warm. If this does not work, do you have to manually add water or is it an auto fill system? Make sure that is working or manually add water.
Oct 30, 2013 | Uponor Wirsbo A3010526 Thermal Zone Valve...
Fan works compreser will not engage can unplug wires from dryer jump cross and compreser will engage.is this low pressure side and just need 8oz of 134a or do need to check other parts of system?PIEASE...
Yes, usually low charge. Add a 14 oz can and see if it works then. It helps to have fill hose with gage with safwe zone on it, so you can watch after adding.
May 24, 2011 | Nissan Frontier Cars & Trucks
Do I need briquettes for my weber silver grill
No, you don't use briquettes with a charcoal grill. Charcoal is slow to heat up any way, adding lava rock (briquettes) would make it even slower and hard to keep lit. However, its OK to add cooking wood chunks after the charcoal has heated up, to add a smokey flavor.
Happy Grilling!!
May 24, 2011 | Weber One Touch Silver Charcoal Grill
My GM5472 (AMD Chip) has been running very hot over the past few weeks - over 100 degrees C! I've cleaned the fans out and now have a fan leaning against the box, which keeps the temp down. Question is -...
-try adding additional fan in the casing -in adding fan make sure that you have a blower fan and a exhaust fan where in air can get in and out inside the case.
-add thermal paste/grease between the processor and the heat sink. it is often used to aid the processor's thermal or heat transfer via heat sink. -you can also add blower fan in the chipset of the motherboard -you can also add heatspreader in the memory. -check the power supply if you are getting enough power -having too much power may result in over heating and may damage the devices -having less power may result slow system and bad performance.
Apr 27, 2011 | Gateway GM5472 PC Desktop
My youtube isnt working and i need it for school
Lets try the following go to msn.com 1.- click to TOOLS 2.- click in INTERNET OPTION 3.- SECURITY 4.- in TRUST SITES click on it 5.- click SITES 6.- in ADD THIS WEB-SIDE TO THE ZONE click ADD you can type all websites you like by adding ADD
When you done click CLOSE then OK.
Now try youtub.com or www.youtub.com if is not accepted try http://www.youtub.com all dipends how you add it in your web-side zone.
Your Ratings is very important to me
Was this helpful?
May 26, 2009 | YouTube Videos
Everytime i go to youtube.com instead of going to the site, it just says Bad Request! this has been going on for a while now..please help!
Was this helpful?
May 20, 2009 | YouTube Videos
Zoning not programmed
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
May 18, 2009 | House Brand Heating&Air Conditioning...
Plumbing Logo
67 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
