Question about Delta 31 - 735A 6'' Belt/12'' Disc 1 PH Finishing Sander
I purchased a Delta 52-612 belt/disc sander only to find that it had some broken/missing parts. Since it is obsolete, will parts from newer sander fit?
It needs the disc table and trunions and drive drums
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 32 Answers
SOURCE: New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Posted on Jul 18, 2009
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
Posted on Nov 28, 2009
  • 122 Answers
SOURCE: My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Posted on Jan 30, 2010
puertobori
  • 7733 Answers
SOURCE: I bought a Delta drum
Go to eReplacementParts.com : Power Tool Parts and Tool Repair.
Posted on Oct 12, 2010
Where can i buy a drive belt for a clarke model bt1009a sander
from Clarke direct or 'sanderparts'.
Clarke CS4-6D Belt and Disc Sander Manual - Clarke International
https://www.clarkeservice.co.uk/manuals/woodworker/cs4-6d.pdf
Faulty goods should be returned to their place of purchase, no product can be returned to us without prior permission. This guarantee does not effect your statutory rights. IN THE BOX. The following should be supplied inside the box. If any parts are missing, please contact your local Clarke dealer. • 1 x Belt/Disc Sander.
Where can I buy a belt for a clarke model Bt1009a sander - Fixya
www.fixya.com/support/t14574446-buy_belt_clarke_model_bt1009a_sander Oct 7, 2012 - The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in. I found a replacement at sdp-si.com, part number A 6R 3-060031. Look here for timing belts (inch), then ...
Clarke Power Products BT1009A - Free Shipping on Orders Over $99 ...
https://www.summitracing.com/parts/clk-bt1009a Find Clarke Power Products BT1009A and get Free Shipping on Orders Over $99 at Summit Racing!
[PDF]CA30 20B - Clarke
https://www.clarkeus.com/~/media/NewClarke12.../PL56091130.as... Translate this page
If the batteries are incorrectly installed or inaccurately connected, the electric components of the machine may be seriously damaged. The batteries may only be installed by qualified personnel. According to the battery model number (WET or GEL) being used, set the functional circuit board and onboard charger (optional).Missing: bt1009a
Clarke Sander Parts ' Buy online at sanderparts.com
https://www.sanderparts.com/categories/Parts/Clarke/ Clarke sander parts - buy replacement parts for all models of Clarke sanders.Missing: bt1009a
clarke model bt1009a parts Google Search
Mar 12, 2018 | Sander Tools & Hardware - Others
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
22 belt disc sander 150xl051
Delta should be ashamed of themselves for putting out a product as bad as this one, belt has no power and disc part is pure junk, they should be rated in the minus. If you find out best best/disc sanders in 2018 go to the link Practical WEN 6502 Sander Review For Improved Sanding Skills
Dec 02, 2013 | Delta Machinery 4x6 Belt/Disc Sander
I have lost the screw that holds the sanding from spinning on its own. I can't find the part number. Could you assist please?
I do not know if this will help because I do not know which screw you need. If you click on the link below you can look at the delta service manual parts list.
http://www.ereplacementparts.com/images/delta/31-695_TYPE_1.pdf
Otherwise can you be more specific on the location of the screw?
Apr 29, 2011 | Delta 31 695 6" Belt/9" Disc Sander
Delta disc and 1" belt worled yesterday, not today. I turn the switch on and the disc "twitches" and the motor hums. I can turn the disc by hand so it's not jammed. Belts are good. Any ideas???
the motor has lost its polarity it uses magnetic electric polarity to turn around. the fault is just as bad as a burned out motor you could have the motor rewound but it would cost more than the entire unit..
sorry
take care.
Aug 03, 2010 | Delta Machinery 1" Belt and 8" Disc Sander
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
May 12, 2010 | Delta Machinery Sanders Sanding Center -...
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Delta 31 - 735A 6'' Belt/12'' Disc 1 PH Finishing Sander Logo
514 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
