Question about PELTON & CRANE 5000 Series Chairman Dental Chair
Chair base will not go down but base will go up
How to assemble executive swivel high back chair
Usually you screw the base to the bottom of the chair and then attach the back and then arms. If it did not come with instructions return it.
Sep 28, 2014 | Boss Traditional High-back Executive...
Rascal scooter
Could have a wiring issue you should look in the console make sure nothing is crossed.
Jul 21, 2014 | Electric Mobility Rascal Scooters,...
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
How to remove swivel base from lazy boy recliner
This individual wants to remove the base from a recliner, not a tv. Take the back off the chair. Turn it upside down and remove four bolts, two front, two back that bolt the base to the chair on arms. Contact lazy boy first. You can get a new base from them that is stationary and put it in place of the swivel. I have same problem. Swivel is constantly turning and drives me crazy.
Jul 04, 2012 | Televison & Video
How to remove the seat of a prono wheelchair
Hi. To lift of the seat, you need to pull the knob under the side of the seat that allows you to turn the seat. While you are pulling upward on this lever, use your other hand to lift the seat of its mount. This might be hard to do if the seat pivot is lacking any lube or a light film of oil.
You might have to disconnect the cable to the joystick control first.
Good luck. Neil.
Aug 23, 2011 | Invacare Pronto M51 Power Wheelchair
Want to get back of chair off the chair
If its a regular office chair then the solution is fairly easy...
Look underneath the chair and there should be a bolt or two screws holding the 90degree arm that the back is attached too. Remove those and you'll have it in two pieces.
Sometimes office chairs have the 90 degree arm attached to the base. In this case you would need to look under the base for the main bolt. Remove that and then the spring inner pole should slide out. From there simply disassemble the reminder bolts.
I always keep track of where the bolts and/or screws go, because when you go to put it all back together it'll make the job much easier. Draw a diagram if needed.
Side note, if you could provide what brand of chair this is I may be able to assist you further, the above is just general knowledge.
Feb 21, 2011 | Office Equipment & Supplies
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Can the MPV 5 be disassembled for transport? I can't find anything on the subject.
The MPV is not designed to break-down easily for transport. The only "simple" thing that comes off is the seat which will make it about 40 pounds or so lighter, so you still have over 150 pounds to lift without taking the batteries out, which would get it down under 100 pounds...still a lot of weight to tote around. To take off the seat, first disconnect the joystick control cable, then unlatch the seat and lift off the base. This is safer and easier with two people.
The cheapest way to transport is using a ramp. Here's where I buy mine for our clients, and they are the strongest and the lowest priced ramps I have found. http://www.pviramps.com/
You can go with an electric lift, but the cost is going to be a few thousand dollars when all's said and done. If you install one on a car, you'll need at least a class II hitch, and I have found that usually you will also have to get air-shocks to compensate for the extra weight on the tail end. Even some vans, like the Honda, sag too much in the rear with a lift and chair on the rear end.
Jun 23, 2009 | NRS Hoveround MPV 5 - Used Power...
PELTON & CRANE 5000 Series Chairman Dental Chair Logo
530 people viewed this question
Top PELTON & CRANE Medical Experts
Electro Med Services...
masud
masud
Rhonda Webster
Rhonda Webster
Are you a PELTON & CRANE Medical Expert? Answer questions, earn points and help others
