Question about Crosley Washing Machines
Water Sprays Upward & All Over - On The Floor - HELP
Crosley 5-Cycle Washing Machine: I noticed suddenly that the water sprays upward and all over, and now goes immediately all over the floor from underneath the washing machine. Please tell me in simple language how I myself can fix this (if possible). Thank you so much. Also, whenever the machine ends the full cycle, it really bangs and jumps up - can anything to be done about that?
  • 87 Answers
Have you checked the hose in the back it might be loose and it sounds like it is out of balence check the little feet that screw out and make sure its balenced and be sure not to over fill with clothing it may need to be rebalenced the drum
Posted on Nov 16, 2013
harley12
  • 22 Answers
SOURCE: Stuck in cycle...
I have the same washing machine. I had the same problem you have. My problem was the timer. It just stops at that one position. If you can slowly move it yourself and it starts to do something after you turn it a little bit then your timer is burn up in that one position. You have to replace it. You cannot tear it apart and try to fix the timer. It is sealed by the factory. UNPLUG THE ELECTRICAL CORD. Take the back off of the panel at the top. Then you will see where the timer is bolted on. Remove the timer and take it to your nearest Kenmore dealer. Make sure you write down the serial and model number off of the back of the panel you removed. They will need it to get you the correct part. You can sometime find some small companies that carry household appliances. They can order it for you at a cheaper price.
Posted on Sep 13, 2006
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
IS THERE ANY PROBLEM IF POUR WATER INTO THE MACHINE WITH A BUCKET WITHOUT CONNECTING TAP WATER SUPPLY HOSE
One problem you might encounter is not having enough water for your cycle or having too much, plus there are times during the rinse cycle that it sprays the water in a little at a time to help loosen the soap and dirt from the clothes. I would recommend leaving it connected to your water supply.
Jul 14, 2015 | Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
No water in washing/rinse cycle of dishwasher
It sounds as if the warter inlet valve (solinoid) isn't working and might have to be replaced. If everything else opeates fine, (unit pumps and sprays water that you added to it, pumps out and drains OK, then it is very likely the inlet valve has failed.
You can check for a blockage in the water inlet line, but unless you have a lot of sediment in your water or use a private well for your water supply, that would be a remote possibility, but worth taking a look at before buying replacement parts, etc.
You can remove the water supply hose/line and check for proper water flow and see if there is anything blocking the water from getting into the dishwasher. Many uints have a filter screen installed in them, so check that to see if it is blocked. Otherwise, look at the inlet valve and see if it is working correctly and go from there in replacing it.
One last thing, make sure the water supply line is actually providing water to the dishwasher, sometimes the water valves some installers use do get blocked, depending on how it was installed.
Jul 28, 2009 | Crosley Dryers
Water level is low
This machine only sprays the water, you may never see the clothes completly covered with water it just sprays the water in intervals. You can download a user guide at whirlpool.com select owner center than literature in drop down menu, requires adobe. Hope this helps
Mar 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Working propoerly?
Yes, they are made that way to conserve water. It is working 100% ok, you will notice it on your water bill and your clothes will be nicer also
Feb 08, 2009 | Washing Machines
Spray on the rinse cycle goes all over
THIS WILL BE SIMPLE =)
TIP THE MACHINE BACK SO YOU CAN LAY UNDER IT
TOWARDS THE BACK ON THE RIGHT THERE IS A DIVERTER VALVE YOU DONT EVEN NEED ANY TOOLS AS THE CLAMPS ARE FINGER CLAMS
THE DIVERTER WILL BE COVERD IN PLASTIC AND HAVE TWO WIRES GOING INTO IT (I BELIEVE ITS RED AS WELL)
MORE THAN LIKELY SOMETHING IS JAMBED IN THERE CAUSING IT TO BE PARTIALLY OPEN DURING THE SPIN CYCLE AND WATER IS COMING OUT ON THE RIGHT SIDE OF THE TUB(SPRAYING IN THE SHAPE OF A FAN) WHEN IT HITS THE TUB(WHICH WILL BE SPINNING VERY FAST) IT GETS THROWN ALL OVER THE CABINET
HOPE I MADE IT AS EASY AS IT SHOULD BE TO FIX
GOOD LUCK
Feb 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Water leaks
sounds as if the outlet pump or hose may be blocked or part blocked
Oct 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
