Question about Kitchen Ranges
I have a Kitchen aid range model ykerc507hs2 , smooth top when we turn off the burners from the control panel the burners do not turn off
TechBrian
  • 15 Answers
SOURCE: wave touch panel comes out of sleep mode by itself
Your range should have a two year part and labor warranty so contact Electrolux to schedule service. They will preorder and ship you the parts prior to a servicer arriving.
Posted on Mar 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Large element burns high
The problem is in the switch not the element.
Posted on Mar 24, 2009
SOURCE: top element only stays on high
The trouble would be a failed infinite heat switch. This is the adjustable switch you are using to set the element to low, medium or high.
**Use extreme caution if you are making the repairs yourself.....Turn off circuit breaker and verify power is off with a meter. 240VAC is present at the switch. In addition, the glass top and elements are very fragile.
Posted on Apr 29, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
pappapumpdaf
  • 635 Answers
SOURCE: Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Posted on Mar 05, 2010
Hello Experts, I NEED some advice to remove the control panel on my Kitchenaid electric range (model KESA907PSS00). I can't seem to get the darn thing off. It's loose @ bottom but will NOT release...
I have owned many mediocre appliances but the KESA907PSS00 is the worst of the lot. The burners turn on if you bump them - a contractor bumped it without knowing and left, a pot with chicken was reduced to charcoal and house filled with smoke when we returned. And burners don't turn on, have replaced three burner controls so far. The front door tempered glass exploded while we were gone one day with oven off. Now the oven will not turn off, have to flip the breaker to shut it down. Though I know it is a Whirlpool at heart, it is my last Kitchen Aid appliance. I will be looking at control panel to replace membrane switch so if you have not solved your problem yet, please advise, might figure it out. Called Kitchen Aid, waste of time. Another Retired Cop
Jan 25, 2011 | KitchenAid KERA807P Electric Kitchen Range
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
the burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Aug 26, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Best Regards,
Bruce
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Top element only stays on high
Apr 28, 2009 | KitchenAid Kitchen Ranges
Kitchen aid cook top gas. iginator consstantly firing with knoob off
strutz, you probabley got one of the valve switches wet when cleaning. It could of shorted out or it might be just wet. Pull the control knobs off the burners and take a hair dryer and go over the valves slowly. See if it stops the clicking. If not you will probabley have to change out one of the switches. Im not coming up with anything with the RGA365 model number. Try the above posted first...Catriver..post back.
Mar 12, 2007 | Sco RGA365 Gas Cook Top Kitchen Hood
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
