Question about Pool & Spa
Temperature on the tub is showing 101, however the water is cold
How do I fix this problem>
  • 717 Answers
This is an indication of a malfunctioning temp sensor. You need a new temperature sensor.
Rod
US Parts Center
Posted on Apr 08, 2014
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Hi.. we'll feel cold after taking bath from? 1. cold water 2 water at 40 c 4 water at room tempreature 3 water at 50c
"we'll feel cold after taking bath from?"
(Let's assume room temperature of the bathroom is 25 c.)
1. cold water
Assuming cold water means below room temperature, for example, 22 c. One taking a bath in water at this temperature would probably feel cold DURING his bath at least at first. However, a cold bath would tend to bring blood to the capillaries under your skin and create a warming sensation. But after you get of the bath tub, you would definitely feel cold unless the room were heated!
3) water at 50c
Most folks would feel quite hot while in the water at this temperature. And after exiting the tub, since the layer of water on his skin would probably still be well above body temperature (37 c), a chill would not set in until the water on his skin cooled down to below body temperature. So if he quickly dried off, he would avoid feeling cold.
2 water at 40 c
While almost completely immersed in the bath water, one would certainly feel warm unless there were a draft in the room, because 40 c is 3 degrees above normal body temperature. For the same reason as stated above (#3), he could escape feeling cold outside the tub if he dried off quickly.
4) water at room temperature
- If I had to select only answer, I would choose this condition that would make one feel cold after stepping out of the bath tub, because:
Upon exiting the tub of water at room temperature, one would certainly feel cold if there were a draft in the room. Even if there were no draft, one would still feel cold, because the water on his skin would be cooler than his body heat (37 c), and cause a finite evaporation of the thin layer of water on his skin, which is a cooling process. The skin's heat would be lost, because its energy would be used to evaporate the water.
Mar 30, 2010 | Scientific Explorer My First Chemistry Kit
Washer only has cold water. Hot water is good to machine but only cold water enters machine on warm cycle, no water ar all on hot cycle.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Dec 25, 2009 | Maytag LAT3600A Top Load Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
No cold water
souds like the cold valve has gone get and expert in to change it or change it yourself you can get parts from espares
Jun 28, 2009 | Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Erratic water flow and temperature from laundry tub faucet..
this is quite possible, the newer units, actually are monitering teh watertemp, as it enters machine, and will either increase or decrease flow of both hot/cold water to maintain what it would consider an optimal temp.. so i would not worry about this issue.
Feb 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Temperature control
hi thanks for the question . make sure the cold water tap is on . if on. no cold water. replace the water valve . thanks the appliance doc
Sep 28, 2008 | Washing Machines
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Fisherpaykel gwl15 washer will not pump down
remove as much water as possible lean washer back against wall ..pump twist locks into bottom of tub remove clamps with fingers pump will twist out no tools needed!!!! clean pump and retry
Sep 09, 2008 | Fisher Paykel EcoSmart GWL15
Pool & Spa Logo
65 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
