Question about Kenmore Dryers
Dryer only works on 1 setting
The time and dry setting knob only works on 1 setting
    Problem Solver:
  • 11 Answers
Not enough info , but ide say the timer/setting switch is bad
Posted on Nov 17, 2013
  • 161 Answers
SOURCE: Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
Posted on Jun 29, 2008
  • 686 Answers
SOURCE: dryer doesn't shut off when set to more dry
moisture sensor problems
Posted on Feb 18, 2009
  • 93 Answers
SOURCE: dryer takes a very long time to dry clothes
dear sir you could check that your vent is clear and the trap outside is not closed or cloged to test your dryer disconect it from the vent if drys good then your problem is in your vent tubing if it does not dry when you have disconected from the vent then check the wire to the ellement most dryer have 2 ellement inside one may be broken this will take a long time to dry if you have a amp probe you can tell wrigh away by checking the total acording to the spec plate on the machine thanks from gilles
Posted on Mar 15, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool gas dryer not working, think the timer is bad.
Sounds like a timer problem .
Posted on Aug 01, 2009
Controlfrk
  • 304 Answers
SOURCE: what is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Posted on Aug 29, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
Dryer timer knob
This control could be the problem IF the blower wheel ain't stripped, the dryer is clean, and the duct work is free of air restrictions.It is located on the blower housing next to the fuse.ec8cbee.jpg
Mar 18, 2010 | Maytag PYE2300AY Electric Dryer
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
Large knob broke
just push in and turn counterclockwise...now the shaft of timer did not break,,,???
Feb 03, 2009 | Frigidaire FEQ332E Electric Dryer
May 30, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
