Question about Singer Sewing Machines
I'm having problems with my singer futura quartet seqs-6000. While embroidering the machine begins to stich but the hoop does not move so all the thread gets caught under it in the bobbin. how do I f
Also when using the software it keeps telling me that my design is to large for the small hoop yet I'm only doing a small monogram.
    Problem Solver:
  • 12 Answers
Remove the bobbin case check it for barbs that has resulted from your needle they grab the thread I just had this issue the only good fix is a new bobbin casing
Posted on Sep 15, 2015
    Problem Solver:
  • 11 Answers
For the hoop, you could turn off the machine and restart, or put in the big hoop and then select the small hoop for ur design. and get some TCL on all the bumps by joining the future group on FB. and don't forget to "pay it forward" back here on this site.
Posted on Nov 21, 2013
4 Suggested Answers
dupina
  • 110 Answers
SOURCE: A brand new Singer Quantum
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Posted on Dec 08, 2008
  • 192 Answers
SOURCE: I have a husqvarna Designer SE. After
Most likely the thread is riding up and out of the tension disks. Look for the small, round opening in the pre-tensioner. It is the metal piece to the left of the horizontal spool pin. If the thread is on the horz spool pin, it will travel in the rounded opening. If the thread is fed in higher up, it can ride up higher in the pre-tensioner, causing it to not be pinched by the pretension spring and it may ride up and over the top of the tension disks. If this is a possibility, rotate the horizontal spool pin out toward you. Place a spool cap on it and feed the thread around it on the right side and below so the thread feeds into the pre-tensioner horizontally and I think that your problem will go away.
The only reason for this to happen is that you are loosing the upper tension for some reason so if my suggestion doesn't work continue to look at the upper tension assembly and the takeup lever.
Posted on May 19, 2009
SOURCE: Thread tangles under throat plate while embroidering
Take the cover off or at least enough to blow the gear drives out around the area of the thread cutter. We use a air pump that you use to blow up an air mattress with. You will also need tweezers to pick out the thread etc. that gets wrapped around the gear and in the teeth. What happens is the gear drive gets clogged and does not turn freely.
Mary
Posted on Jul 26, 2009
Singer futura quartet seqs 6000 keeps giving me a broken thread error. Thread is not broken and I have done tried the unwaxed dental floss and canned air, Please help
Hello
Embroidery sewing machines will often give this error message due to low "drag" on the thread. Try placing the spool of thread upright into a cup on the floor and lead-up the thread as normal for threading. Make sure that the thread does not catch on the thread lock on the spool.
Happy stitching
Sewingirl/
Apr 20, 2017 | Singer Sewing Machines
Two questions i own a futura embroidiery sewing machine. I need to purchase a beading foot where can i purchase it 2) My bobbin casing keeps loosing I have to constantly stop sewing and tighten it
First, look for a replacement bobbin case for your machine. And while you doing that, also look for a beading foot.
Try some of the online sewing vendors:
Bobbin Case Singer 416444401
Singer SEQS 6000 Futura Quartet Par
Finding a beading foot make be difficult, but you may be able to find a snap-on adapter and a snap-on beading foot for your machine.
Oct 25, 2016 | Sewing Machines
Which one is the best for Embroidery Singer XL 420 or Singer SEQs 6000?
Difficult to advise since we really don't know your criteria.
SEQS 6000 FUTURA QUARTET
FWIW, I would be hesitant to purchase a machine with so many functions, ie sewing, embroidery, serging. Seems like a lot of things to go wrong.
XL 420 FUTURA
Your best bet is to do a lot of research on the internet. Read the reviews from people who have purchased these machines. Then go talk to a Singer specialist. Only when you have gathered as much information as you can are you able to make an educated decision.
Jul 22, 2016 | Singer Sewing Machines
SINGER QUARTET FOUR IN ONE HOOP ERROR
There are a couple of reasons that this can happen. First, download a patch on the singer Futura support site, www.futura-support.com. Download the patch, close the Futura program and double-click on the downloaded file. It may help with your error.
The second reason it can happen is because the USB plug on these machine is out a little too far, and the cable often doesn't seat quite as solidly as it should. Put the cable plug in the machine, making sure that it sits squarely and securely, and tape it in. When you unplug, do so from the computer side and leave it in
If you've applied the patch and taped the plug, the third reason might be the USB cable itself might have a loose wire, so that it works some time but not all the time. If that seems to be the case, try another cable.
Aug 05, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura ce-100 embroidering in the wrong place
I decided to simply start from the beginning and start all over. I turned off the machine, detached the embroidery unit and blew into the sensor (where the machine and embroidery unit connect). I'm not sure what the problem was, but it was fine after that! Just goes to show that no matter how frustrating things can be, it pays to just take a moment and start over!!
Feb 18, 2009 | Singer CE-100 Futura Computerized Sewing...
Hi, I'm trying to embroider using my Singer Futura CE-100. After it starts to embroider, it will either bunch up bobbin side or the machine will beep, and the computer says to turn it off, remove hoop,...
could be a threading problem. on the top of the machine, where you go under the plate, pull the thread back and forth like you are flossing. you should feel the thread snap around the 2 wheels, then continue threading. hope it helps
Aug 15, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
296 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
