Question about Yamato AccuWeigh PPC-200W Digital Washdown Scale 40 lb
--E 105 error code. scale not functioning properly
Power on, power off works. nothing else functions. "--E 105" is displayed and does not change when scale is moved, or one of the other buttons is pressed. The stabilization icon is illumiated, meaning the weight on the scale is stable,regardless of whether or not the scale is stationary on a table or being rotated freely in the air.
Canon IRC2620 Error Code E000001-0004
This is standard error code for Canon and the fuser unit. The error can be reset by being ready to go into service mode quickly. First press the additional function button, then the 2 & 8 keys at the same time and then the additional function key again. The display should change to the service mode screen, indicating " COPIER " and other accessories. Press " COPIER " then accross the top you should see a menu and select "FUNCTION" then select " CLEAR", then " ERR ", then " OK." This will clear the error from the copiers memory. Turn off the main power switch, wait a few seconds, then turn the copier back on. If you continue to have this error you will have to replace the fixing assembly and if it is similiar to the IRC3220 then you ahve only two screws to remove and the whole unit comes out. You will be saving a service call and I do believe the fuser is over $500. I usually don' tknow the prices of items until I have to do a quote for a customer. Good Luck.
Sep 04, 2012 | Canon imageRUNNER C3200 Copier
ERROR CODE E000004-0001 IN 8070IR COPIER
This is error given by the thermistors in the fuser. Not detecting a temp change or too much temp difference between the thermistor ( front edge and Middle ). You can reset it by going into service mode. Press additional functions, then 2 and 8 at the same time, then additional functions. Press copier, then function at the top of the display, CLEAR, then ERR, then OK. Power down the copier using main power switch. Wait a few seconds then power up again. If the error continues then you will have to have the thermistors replaced if the heater is working. The heater should give an E000 code if not heating up.
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
I can't make my canon mp460 do anything. little used i've just taken it out of it's box again and changed the ink cartridges but nothing. error 5010 showing.
hi
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request."
or
go to following link you will have more solution
http://www.subnixus.com/error-codes/error-5010.html
May 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My cannon iR3320 displays error code E000002-0000. the problem started today after yesterday's power surge
Most likely an error reset will take care of the problem. Get into service mode by pressing the additional function key, 2 & 8 key at the same time, then additional function key again. Press copier, function ( at top of display ), CLEAR, ERR then OK. Power down and back up again the copier. If error continues then the fixing film assembly will have to be replaced.
Dec 08, 2010 | Canon imageRUNNER 2200
We are getting the error E000001-0010 on our canon imagerunner 5070. What is this?
Need to try to reset error code. Heater code ,Machine didnt get to temp in time. Additional Functions then the two and eight at the same time Additional Functions again. This must be done quickly. Copier
Aug 30, 2010 | Canon Office Equipment & Supplies
Printer displays 510 error code. I need the local service center address
HI
Got this from usa canon.com website click here and type error code in the search box
a list of the error codes will be displayed and you can then click on the relevant one.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
Jun 20, 2010 | Office Equipment & Supplies
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Apr 17, 2008 | Canon imageRUNNER 5570 Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Yamato AccuWeigh PPC-200W Digital Washdown Scale 40 lb Logo
248 people viewed this question
Top Yamato Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Yamato Measuring Tool and Sensor Expert? Answer questions, earn points and help others
