Question about Sony DAV-S400 System
Fm radio works in mono only - Sony DAV-S400 System
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 407 Answers
Hi, the Dav-s400 system was one of the units that had bad solder joints and this led to intermittent bad power contacts with different issues arising. There is a page on the internet that helps you to take apart and resolder the joints if you are that way inclined. I done mine myself and followed the instructions from the internet page. If you type in Dav-s400 bad solder joints you should find the page. Its that or you put it into a repair shop its not a big job. I hope this cures your FM problem. p.s. make sure the aerial is plugged in properly first, it could be something has maybe dislodged it from the back panel.It is just a very thin black wires on a plastic aerial holder.
Posted on Nov 29, 2013
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Why does my 1998 chevy blazer have problems starting when the temp. falls below 20 degrees.
Could be a battery that isnt turning the starter the greatest. Try a bigger battery with higher cold cranking amps.
Jan 10, 2015 | OEM 1998 Chevy Blazer Radio / CD Player...
2013 Santa Fe Sport radio on am 670 cuts out and back in with varied times off. If I toggle to the next station and back it is there right away. The station does not have a problem on my other car. This is...
cuts out ?
well, all FM radios cut out for.:
1: weak station.
2: stereo can not be held in properly( can be bypassed on most RAD , pick mono)
3: AGC drop out, same as #1
on better radios (RTM) you can defeat these default features.
set the FM to mono channel mode, and now you hear all stations.
also kill the AGC mode. this allows you to hear
the station. and static or both. like a Marconi radio of days of old.
modern radios are programmed to blank weak stations.
tis a fact. im a tech and tuned these features, for 50 years.
ok the fix,
1: move closer to station
2: get a better antenna (vast choices)
3: go to station and turn the gain knob up and get arrested by FCC.
Oct 14, 2013 | 2008 Honda Ridgeline
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
Can't find the clear tuner fm frequency
I have a JVC deck myself and had the same problem but if you read the manual it recommends that owner should use mono mode when using FM. Since changing to mono I am able to locate radio stations (frequencies).
Here is the link to the manual
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/105/105KDLX50.PDF
Sep 19, 2010 | JVC KD-LX50 CD Player
I have a new Onkyo TX-SR508 receiver. When listening to FM radio the audio cuts out repeatedly for anything from a few seconds to a minute. Power fluctuation is very unlikely to be the problem. Signal...
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Jul 14, 2010 | Onkyo Audio Players & Recorders
Programing the radio stations
You just press the program button on the front of it. It's next to the Stereo/Mono button!
Jul 04, 2008 | Sony MHC-RX66 Shelf System
Iriver e10 how to record radio
http://www.osnews.com/story/17860/Review:_The_OGG-Compatible_iRiver_E10
After you long press the right arrow button the special menu appears: Record, Saved FM Recording, FM Recording Quality, Save Preset, Stereo/Mono, Auto preset, Tuner region. The FM Radio works very well, it has amazing reception compared to cellphones with FM support, but it won't continue playback while you are reading a text file. You must stay in the FM app to have it activated.
May 19, 2008 | iRiver E10 Digital Media Player
Sony DAV-S400 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
