Question about NEC NP210 DLP Projector
Dead pixel dlp projector - NEC NP210 DLP Projector
How to fix the visible pixels and get clear picture
Dead pixels cannot be fixed. The lcd would have to be replaced
Aug 17, 2016 | Office Equipment & Supplies
Why are there lots of black dots on the screen?
Those "black dots" are either dirt on the inside of the projector or, more likely, dead pixels on the LCD light valve chip.
May 05, 2015 | InFocus X16 DLP Projector
Dots on projection
Hi, look like dead pixel on DMD lcd cpu unit... I have the same issue... Open projector and check the lcd surface with a magnifier and clear light, you will be able to see the 'point dead'... Only replace with a new one look to be the solution. FOR ACER x1260 picture follow...
Feb 08, 2014 | Acer X1260 DLP Projector
Suddenly, benq mx511 has white pixels showing up....multiplying every day...now the projected image consists of 50% snow.
It probably has the same DLP chip as my Mitsubishi television. The mirrors in the chip set get stuck and create the white spots. There is no way to fix this other than replacing the DLP chip.
Feb 04, 2013 | BenQ MX511 3D Projector
White spots on projector
firstly make a clean for your projector DMD chips or color weel, if it still ahs whie spots, It should be dead pixels, since for the DMD chips issue. you have to replace a new DMD chips. i have DMD chips fit for Optoma EP761, it will cost USD123 with shipping
Jan 11, 2013 | Optoma EP761 DLP Projector
Hi, I have a projector Optoma EP7155 and it appear white and black spot like dead pixel, I would like to know where I can buy a DMD chip with the CCD and how much it will cost. Thank you
global projectors is one source. You need to find out from Optoma the chip you need or take apart the machine and look at it. From China they run about 200 bucks. I've only done Mitsubishi so far.
Dec 16, 2012 | Optoma EP7155 DLP Projector
Mitsubishi projector xd50u dlp chip repair
Normally the dlp going bad would be white or black spots. Dead pixels. DMD/DLP is about 200$ from china. I've got a video of the repair on an ex51u
Dec 06, 2012 | Office Equipment & Supplies
How do I repair stuck pixels on a DLP projector
you have certification in this field or u have knowledge about repairing so try other wise do not try go to technician and they repair your projector
Sep 29, 2011 | InFocus IN102 DLP Projector
Hi , 2 weeks ago i noticed some dead pixels showing up on my screen (white dots) since then i'm up to 10 dead pixels. What can i do? I heard it might be the dlp projector that has to be replaced...
White pixels are STUCK pixels, not dead. Read the warranty beacuse at a certain number of stuck/dead pixels, the tv is repaired for free by the seller if is in warranty period.
Nov 02, 2010 | Samsung HL-S5686W 56" HDTV
NEC NP210 DLP Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
