Question about Sony CDU5211/5221 Internal 52x CD-ROM Drive
CD ROM TS-H192C/SH-C522C Gets off When Connected
My CD Rom shows power failure when IDE cable is attached; no Ejection no Power LED.On removing the IDE Cable the power lED starts blinking and Ejection can be done.Please give me some pointers.
  • 363 Answers
Check that the power plug is getting both the +5v and +12v and there is not a fault with the power plug.
Posted on Oct 07, 2007
SOURCE:
How to take a cd rom out of the computer
Open the cabin of the system and remove all the screws in the system. Then remove the screws which is connected in the system and unplug the IDE cable & power cable which is connected in the computer ROM at last pull out the CD ROM from the system cabin.
Nov 03, 2010 | Computers & Internet
What is CSM/SLA -of CD-RW DRIVE SH-R522
It's not CSM/SLA. The letters CSM are directly over SLA, and they are vertically read as CS, SL, MA -which stand for Cable Select, Slave, and Master. They are found on IDE drives as the jumper points. Depending on where the drive is connected on an IDE cable, the jumper should match accordingly. CS is often used for either, preferably when there are no other devices on a single IDE cable.
Sep 27, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My TS-H653N CD Rom device does not work. What do
Buy a new one and replace it. Follow this tutorial on how to do it:
1. shut off your computer.
2. Unplug the power cord from your computer and the rest of the wires from the back of the computer.
3. find a sturdy flat surface on which to work on
4. unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
5. open your computer up by taking the side panel off, or sliding the cover off.
6. unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
7. unscrew the 4 holding screws on both sides of the cd-rom drive.
8. now, you just have to remove the cd-rom drive, carefully by sliding it either forward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
9. Do everything in reverse to install a new one.
Jul 19, 2010 | Compaq Presario 5000 PC Desktop
Drive not spinning properly When I insert a CD, drive is spinning but not properly so, the data on CD can not read
drive is conected to what component(laptop,desktop,tv) and then take that out from that component reset the cables which is connected back to it.Reinsert the drive and then check the functionality
Nov 29, 2009 | Samsung SH-C522C/BEWE 52x CD-ROM Drive
Unable to detect or use my cd rom
Is this in a desktop or laptop? I will assume it is in a desktop
This could be caused by the jumper setting on the CD ROM is the same as another drive in the PC.
It could also be a loose or damaged IDE cable / power cable to the CD ROM.
Open the case of the PC and verify the IDE and power cable are securely in the back of the drive and the IDE cable is securely in the motherboard port.
If there is a 2nd device connected to the same IDE cable, verify one is set to MASTER and the other is set to SLAVE. Cable Select (CS) setting can fail - placing both devices as MASTER/SLAVE will eliminate a failed CS logic.
If this is in a laptop, turn the comptuer off and remove the battery and AC power. Remove the CD ROM (if the unit can be swapped) and re-insert the drive back in the laptop. Reboot the laptop with the drive in the laptop and test.
Nov 18, 2009 | Fujitsu Computers & Internet
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
My computer does not show my D:/drive, so it does not work
I would assume that your D drive is your CD Rom Drive. If you go into My Computer and the drive isn't there, Lets assume first that there is a problem with the Drive. If you have power to it and the drive does open to let you insert a disk, then our next step is to see if your data cable running to the drive is connected. Make sure that all power cables are unplugged before you open up the computer. Once opened look at the back of the CD Rom drive to check that the power plug is connected. Its the first set of 4 wires closest to you. The next cable next to that is the CD Rom Data IDE Cable. This cable must be plugged in all the way. Most of the IDE Cables will have a red stripe on one side. Make sure this red stripe is closest to the power cable for the drive. This will insure that you have this plugged in correctly. If you follow the IDE cable from the CD Rom to the mainboard (Motherboard) , you can make sure that this end is also seated firmly to the board. If all this is as it should be, go ahead and plug all your cables back in and restart your computer.
If this still doesnt solve your problem you might want to check your bios and insure that the CD Rom is recognized. It will show up in there if it sees it. If any of these solutions dont solve your problem, I would be leaning toward a bad CD Rom Drive.
Joe < Data Miner >
Nov 01, 2008 | Computers & Internet
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Open Questions:
WEBROOT cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 16, 2019 | Webroot Computers & Internet
Rocketmail Technical Support Phone Number # I:8OO-828-O294 .U.S.A This Rocketmail USA phone number is ranked #2 out of 2 because 7,728 Rocketmail USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Rocketmail USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, Rocketmail USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Rocketmail USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Rocketmail USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Rocketmail USA Calling Rocketmail USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Rocketmail USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Rocketmail USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Rocketmail USA's phone numbers against each other. Contacting Rocketmail USA in General While I8OO8280294 is Rocketmail USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach Rocketmail USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Rocketmail USA.
Oct 16, 2019 | Best Computers & Internet
Zoho Technical Support Phone Number # I:8OO-828-O294 .U.S.A This Zoho USA phone number is ranked #2 out of 2 because 7,728 Zoho USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Zoho USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, Zoho USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Zoho USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Zoho USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Zoho USA Calling Zoho USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Zoho USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Zoho USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Zoho USA's phone numbers against each other. Contacting Zoho USA in General While I8OO8280294 is Zoho USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach Zoho USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Zoho USA.
MCAFEE cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This MCAFEE USA phone number is ranked #2 out of 2 because 7,728 MCAFEE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the MCAFEE USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.
Oct 16, 2019 | Mcafee Computers & Internet
See all Sony CDU5211/5221 Internal 52x CD-ROM Drive Questions
Sony CDU5211/5221 Internal 52x CD-ROM Drive Logo
235 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
