Question about GE WJSE4150B Top Load Washer
Control board i need a part number
How do I fix control board clock that not display clock and some controls functions not work on a slide in range kenmore
Hello. I need the model number to help you accurately. The symptoms you describe point to a defective main control board or defective display board(depending on the model range you have). Some ranges have the touch panel and display all-in-one and others have separate boards--I need the model number to give you the exact part number(s).
Sep 13, 2015 | Kenmore Kitchen Ranges
Control board
Hello, check to see if the board is receiving 120 volts at the L1 and neutral terminals, if you are then the board will need to be replaced, if you are not getting power then trace the wirimg back to where the voltage stops, for example could be a bad door switch, fuse, circuit breaker. If it is the board then just write down where all the wiring goes or sketch it out on a piece of paper and then remove the board and take it to a Hvac supply store, that way they can match it up for you and get the exact board you need.
May 08, 2012 | Heating & Cooling
Dryers stops after 30 seconds of running.
#5 post_old.gif September 24th, 2009, 08:49 AM jake.gif?dateline=1263924303 Jake user_offline.gif Appliance Tech - Admin Join Date: Aug 2004 Location: Springfield, Oregon Posts: 32,822 Thanks: 48 Thanked 1,244 Times in 1,238 Posts reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_highpos.gifreputation_highpos.gifreputation_highpos.gif icon1.gif So you need the motor control board #17 here?
http://c.searspartsdirect.com/lis_pn...2059-00001.png
Here's the motor control board for your model:
Manufacturer's Number: 8544799
Jun 30, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
How do I find the part number for replacing control board for GE?
WB27T10290
I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
Jun 02, 2010 | GE Profile JTP56 Electric Double Oven
2nd Hand simpson 880 dishwasher cant read numbers on dial. Can read a 6 but that is all. Have no manual, need to know which number is where on the dial.
is control board problem, also check for mains voltage, normaly is a mains cables problems.
if is +\- 10% tolerance (110V or 220V) of machine supply is ok, then is control board is defective, needs to replace\repaired.
is normal after a storm, some dishwasher (electronic) control boards be burned.
Feb 14, 2010 | Dishwashers
Philips 47PF9441D/37 Control board
Try this company' they reverse manufacture about every brand and do warranty their products:
Jimmy's Parts
BTW, the part number for the board should be ON the board. Since they never seem to stop making changes, it will probably be on a sticker or hand-stamped and will often have a 'Rev.' note with it. You can also do a search at that link for the control board by name with your model number.
Dec 09, 2009 | Philips 42PF9956 42 in. HD-Ready Plasma...
My Whirlpoolis showing F-1 Error of the LCD display? What can I do?
F1 code on your oven means "Electronic control malfunction". Clean contacts and reconnect all wires on the control board. If it does not help - replace oven control board. You'll also need to program the oven cavity size in the new control board. Model number is incomplete, so can't tell the part number, can be either 8301919 or 8301345
Oct 13, 2009 | Whirlpool RBS245PDS Electric Single Oven
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Motor control board needs replacing
You need to get the model number off the door jam or from the back control panel to order the correct board.
Looks like the right one to me you have listed already , once you get the part number for the actual motor board then you can search on line for the best price on one.
Phil
Apr 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Control board
Don't let it confuse you with all the part number mumbo jumbo. Goto ILO, they have a tab for control boards, go there and then look for the part number with your size tv in it. Mine was a 32" and the number 32 was either the first or last number in the part number.
Enjoy!
Willis4play
only 14.95 for the one I needed
this link is for the part for my 32" ILO
http://www.shopjimmy.com/showparts.cfm?item=334904&ps=3349&pn=4
Sep 02, 2008 | Televison & Video
GE WJSE4150B Top Load Washer Logo
13 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
