Question about AEG Washing Machines
Aeg lavamat 6753 sensotronic
Motor
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Posted on Nov 18, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
May 27, 2014 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 72640
Probably the motor is broken. Or the tachometer is loose from the motor.
Dec 26, 2007 | AEG Lavamat W1450 Front Load Washer
Washing Machines Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
