Question about Mercedes E-class E320 E350 E500 E550 E63 Exterior Accessory Chrome Abs Molding Trim Kit 2003 2004 2005 2006 2007 2008 2009
E320 cranks well but does not start
130000 miles
  • 4 Answers
Ignition needs 3 things, a spark, a supply of fuel and air and rotation (cranking) and these three are choreographed via timing. Unfortunately you haven't given enough information to say which it is, so maybe start by checking first that your battery is fully charged and then inspect the spark plugs and leads. You will need an ohm meter to test the ignition coils and you will need to find out what the correct values are for your car. If all that is fine you can move on to fuel supply. Quick and dirty check is to disconnect the fuel line from the injector rail and try starting the car. Have a container ready to catch the fuel, it should spurt out quite forcefully. If it doesn't you may have a blockage, a dirty fuel filter or a dead pump. This leaves you with air (for the fuel air mix) and timing to check. You really need a diagnostic computer at this point but you can still try manually cleaning the MAF sensor, checking all the wiring to it and intake temperature sensor for loose connections and removing all the fuel injectors and manually testing them with a 12v source. I don't know your level of experience, none of this is too difficult but don't try to fix it without help if this is your first attempt at DIY.
Posted on Nov 17, 2013
1997 E-320. Why doesn't it start?
Do you have it in N -neutral?
97 E320 Engine Won't Start - MBWorld.org Forums
mbworld.org/forums/e-class.../298412-97-e320-engine-won-t-start.html
May 15, 2009 - Hello ladies and gents, I bought a 97 E320 on February with 82k miles on it. ... hours I got out of work and try to start the car, it cranks but the engine justwon't start running. ... Drives: 1997 s320, 1997 e320 ... Cognomen is in homage to the late great Janis Joplin "Oh lord won't you buy me a Mercedes Benz". 2003 E320 cranks but won't start...
Oct 20, 2013
E320 cranks over but won't start
Mar 9, 2013
HELP....KEY WONT TURN ,CANT START CAR
May 17, 2011
W210 won't start.
Feb 13, 2008
More results from mbworld.org
1997 E320 Wont Start - PeachParts Mercedes ShopForum
www.peachparts.com > ... > Tech Help
Jul 2, 2008 - My 97 E320 wont start. ... 1997 E320 Wont Start ... So, we know that any engine won't start if it has no spark or no gas, so that is where we have ...
1997 E320 Trouble Cranking - YouTube
? 0:31
https://www.youtube.com/watch?v=AJu0k_rRb_o
Apr 4, 2013 - Uploaded by Roy Carlsen
1997 E320 Trouble Cranking ... 1998 Mercedes E Class (E320)Start Up and Review 3.2 L V6 - Duration ...
Dec 10, 2015 | Mercedes-Benz E-Class Cars & Trucks
Wont start
It might not even be a fuel pump problem. If your check engine light does not light up, on the dash, when you turn on the ignition, your main computer ecu might be in need of repair. Search for the 'delayed start, no check engine light problem,' here on this site.
May 15, 2013 | 1995 Jeep Grand Cherokee
2005 E320 50000 Miles service
oil change, check all fluids, rotate tires, fuel filter, check all filters, check valce clearence, (what book says), check brakes, check cooling system and flush cooling system
Sep 03, 2012 | 2005 Mercedes-Benz E320 Sedan
My 98 e320 runs and then dies...? Sometime crank right up and run sometime won't crank for a while. Replaced pump and filter ?.
you should check on your battery cables,chasis cables, and engine bay cables related to your ground or bad connection in between connectors, terminals or hubs.
May 04, 2012 | Cars & Trucks
1995 E320 battery drained dead,
The anti-theft system is likely the problem. It needs to be reset.
Apr 22, 2012 | 1995 Mercedes-Benz E-Class
White Smoke
change the bunk where you put petrol or diesel. Because it will not be so quality.
Apr 19, 2012 | Toyota Camry Cars & Trucks
When to change transmission oil in manual transmission.car has 130000 miles and also timing chain change
Transmission oil is recommended to be changed every 50,000 miles
Unless the timing chain is making a noise or broken teeth, they need not be replaced
Timing belt should be changed every 60,000 to 105,000 depending on the vehicle
Sep 16, 2009 | 1998 Toyota Corolla
2005 Merceds E320 wont start
Did you try starting it in neutral? There is a safety interlock for starting the car in park or neutral. Have them check that.
Jul 28, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Mercedes E-class E320 E350 E500 E550 E63 Exterior Accessory Chrome Abs Molding Trim Kit 2003 2004 2005 2006 2007 2008 2009 Logo
89 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
