Question about Panasonic Lands Phones
The button to make and receive calls not working
    New Friend:
  • 56 Answers
Replace phone
Posted on Nov 17, 2013
I just bought the Elite Flip earpiece. It is pairded. While driving I receive a call I have to retrieve my 3G I phone, turn it on, accept the call, then press the elite flip bar in order to use it...what...
It *should* connect to your phone by just pressing the call button with a call comes in. (They all work this way). My guess is, based on your description, is that you are not just pressing the call button, but holding it. This resets the headset back to default and unpairs the phone. When you receive a call (after making certain it's paired) is to just tap the call button once.
Apr 27, 2017 | Motorola Mobility Elite Flip Bluetooth...
Htc g1 won't receive call
cal button is not working how to irecive the calls
May 22, 2012 | HTC G1 Smartphone
We have a Panasonic KX-T7433 telephone at work but 2 of the phones do not ring when we have a call we have to go and pick up the main phone at the other end of the room. We can call out on the phones but...
From the phone, press intercom and dial 790. That clears any "cleaning person" button presses. Check the ringer control button on the left side of the phone to make sure it's on. The "we can't pick up the call" is disturbing because the line should appear on your phone. In a TD system, the lines are normally numbered 01-12, but that's on this side of the pond. If you have ISDN ot EI trunks, they may be different. In a standard key system, the line buttons are called Single CO (SCO) buttons and are programmed by prressing Program 99 on an idle phone, then the button and reading them. If they don't say SCO 01 02 03 etc, you dial 0+01 02 03 etc STORE to change them.
Pick up the handset and drop it back down when you're finished.
Carl
Jun 30, 2011 | Panasonic KX-T7453 Corded Phone
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
The touch-screen of my phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the lasr dialed or received. Even the accept / reject...
The touch-screen of my china phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the last dialed or received.
Jun 29, 2010 | HTC Touch Diamond Smartphone
I can receive calls but cannot send the keypad is locked
keypad is problem.dis happens always on repeated use.
Sep 27, 2009 | Motorola Mobility RAZR V3
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Instructions for super nintendo games on the intrenet
Here is the controller instructions for "John Madden Football"
CONTROLS KICK OFF Y Button call onside kick formation B Button kickoff, activate closest defender A Button call audible RECEIVING ONSIDE KICK Y Button attempt to receive kick on the left side of the field B Button attempt to receive kick in the center of the field A Button call audible, attempt to receive kick on the right side of the field OFFENSE BEFORE THE SNAP X Button fake snap B Button hike ball A Button call audible OFFENSIVE AUDIBLES X Button cancel audible Y Button running play B Button anti-blitz play A Button trick play OFFENSE AFTER THE SNAP Y Button dive B Button break tackles A Button spin PASSING X Button pass to receiver in window x Y Button pass to receiver in window y B Button show passing windows, pass to receiver in window x A Button pass to receiver in window a RECEIVING, RUNNING X Button reach for catch Y Button dive B Button break tackle A Button spin DEFENSE BEFORE THE SNAP B Button activate defender A Button call audible L or R Button line surge DEFENSIVE AUDIBLES X Button cancel audible Y Button stunt B Button blitz A Button defend against run DEFENSE AFTER SNAP X Button reach Y Button dive B Button activate defender nearest the ball A Button power tacklehttp://www.allgame.com/game.php?id=2510&tab=controls
Nov 23, 2008 | Video Game Consoles & Games
Lands Phones Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
