Question about Sony VAIO PCG-5212 PCG-5426 PCG-551L PCG-560K PCG-560P PCG-57... Hard Drive
Sony vaio pcg-551l factory restore
What keys to press to restore to out of box state
  • 207 Answers
SOURCE: manual for my sony vaio pcg-u1 notebook
go to the wbsite enter ur laptops model no and download it
Posted on May 22, 2008
SOURCE: how to reformat my sony vaio PCG-7L1M
abcd
Posted on Sep 26, 2008
SHOGUN125
  • 58 Answers
SOURCE: drivers for keyboard funtionof Sony VAIO PCG-GR300P
You can try using and typing :" driver VAIO PCG-GR300P " ( ex: using : google search ) there is many alternative web to dowlnload driver for you
Posted on Jan 30, 2009
SOURCE: sony vaio vgn-sz330-p factory restore
i have sony vaio (model vgn-sz680). i need help to reboot my laptop to factory setttings. i dont have restore cd.
Posted on Aug 14, 2010
bronk50
  • 27725 Answers
SOURCE: hi i have a sony
windows cant find the operating system to boot from check that there are disks in usb cd/dvd or floppy if there is an external floppy drive if there is nothing in these drives
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Posted on Jun 16, 2011
I have a sony vaio PCG-TR3AP that i want to put back to factory settings but i do not have the disc how do i do this?
do it using system restore method.create a restore point or select the date at which you want to restore and just do it.you will find it in system tools
Apr 02, 2012 | Sony VAIO PCG-TR3AP1 Notebook
Reset sony vio pcv f11m to factory settings
Sony desktop computers can be placed into factory restore mode by shutting them completely down, and then pressing the VAIO Assist button to turn it back on. Follow the on-screen menu to get to the restore mode that resets to factory state.
Mar 01, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
I want to reset my sony vaio
I'm assuming you want to restore your computer to the factory settings, so here's how to do that.
1. Restart your computer
2. Hold down the ALT key and press F10 repeatedly as it restarts.
3. This should initiate the factory restore option, which will reset your computer to an out-of-box state.
Hope this helps!
Aug 25, 2011 | Sony VAIO VGN-T1XP/L Notebook
How to do full system recovery for my sony vaio PCG-4JBP? thk u
Not sure what you mean when you say "full system recovery" but the operating system will have system restore points that you can access from the control panels system protection option. If you want to perform a factory default reset, start up the laptop and then look out for options that can be accessed by pressing one of the number function (Fn) keys. I believe the Vaio range comes with an option to restore the laptop back to it's shipped factory defaults, the interface is reliable and did a great job when I restored a Vaio VGN-NW20EF, came out like new!
Apr 12, 2011 | Sony VAIO Notebook
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
My Sony Vaio PCG-K25 wont gp pass the black screen. I hear the fan and the power is on but the screen remains black. I took the battery out and had it powered through the chord. Still now working. Please...
Hello.
Either you have a memory issue or operating system problem.
First, try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Dec 08, 2009 | Sony VAIO PCG-K25 Notebook
How do I restore my Sony Vaio PCG-Kits orginal
try strart --> all program --> accesories --> system restore
Nov 18, 2009 | Sony VAIO PCG-K23 Notebook
System recovery #2 doesn't work
take out recov disks and do this to restore ur system to factory default all data will be wiped off from C:
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
tell me if it helped and rate me well or ask for more!
Apr 08, 2009 | Sony VAIO PCG-V505EC Notebook
Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Dec 04, 2008 | Sony VAIO PCG-TR3AP1 Notebook
Open Questions:
Sony VAIO PCG-5212 PCG-5426 PCG-551L PCG-560K PCG-560P PCG-57... Hard Drive Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
