Vga input to my mitsubishi Medallion hdtv 1080 doesn't work
    Scholar:
  • 140 Answers
You can't just plug in the input and expect it to work. You have to bring up the input selection screen on the TV first and select that specific input. Read the manual to see how to select different inputs and you should be fine.
Posted on Nov 16, 2013
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Posted on Jun 14, 2008
SOURCE: Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Posted on Jan 22, 2009
SOURCE: mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
Posted on May 04, 2009
SD Tech
  • 14553 Answers
SOURCE: Misubishi Medallion 1080
If this is a ws-65411: it sounds like one of the two STK-392-110 convergence IC's is bad; you need to have both replaced at the same time; I do this type of repair(done hundreds of them) and most can be done right in your home.
The two ic's can be purchased on Ebay for about 12 dollars plus shipping.
This is the slow time of year for TV repair shops--find someone in your area who knows how to do this kind of repair---here shops charge 3-4 hundred but I charge 200-250 total depending on brand of set.
Shop around and if they insist on "taking set to shop" keep looking---any good tech can do this repair in your home---MAKE SURE HE CHANGES BOTH of the IC's!
I do this here for free so if this has been helpful give me a vote here.
Posted on Aug 24, 2009
Testimonial: "very helpful"
ladywinn
  • 5138 Answers
SOURCE: my 65 in mitsubishi medallion hdtv 1080 wont turn
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
Posted on Nov 18, 2009
Testimonial: "excellent knowledge and communication! "
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I have a mitsubishi medallion 1080 series hdtv. I can't figure out how to switch it from cable tv to a screen I can play my x-box game on.
you should have a button on the remote marked input or source or comp or HDMI one of those should fix it just go to the input that your xbox is connected to
Dec 04, 2010 | Televison & Video
Why can't my Mitsubishi Medallion go to 1080 with my Direct TV HD service?
if it is a ws-65613 you would have to be connected to the DTV component input on the back of the set as this is the only HD input for this model.
If the set will not go to that input (skips it by) let me know as there is a way to restore missing inputs--if you hook HD in any other way it will not work on this model; let me know if you need help;
I am here to help and know these sets well.
SD TECH
Mar 01, 2010 | Mitsubishi WS-65613 65" Rear Projection...
My mitubishi medallion is 1080 but is playing in 420. how do i get it back to 1080?
I don't think you can change this setting it is playing in whatever you are sending to it ie 480I . If you send it a 1080 picture then it will play in 1080.
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer flashing
remove the lamp and check to see if its ok, if ok replace lamp thermal sensor
Mar 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 1080 HD Medallion
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
May 30, 2008 | Televison & Video
No Remote need to set up for DVD Video (Mitsubishi Medallion HD 1080)
What you do is match color with color, just make sure if you are putting in Video 1, 2, 3 etc. then you have to set your tv to that input with that Device/input button.
Mar 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
