Question about Kenwood Remote Control RC-150 p/n:A70050405
My Kenwood RC-150 Learning Remote. How do I delete a programmed key
I accidentally pressed the main Volume Decrease Key to turn TV on. Now when I press the Volume decrease key the TV turns off. How do I delete the programmed keys and start over?
    Top Expert:
  • Kenwood Master
  • 36,301 Answers
Remove the batteries and let the remote sit idle for a time until retained memory fades. Reinstall the batteries and start over again.
Posted on Nov 16, 2013
How to reset the Kenwood vr-716
Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
Nov 13, 2016 | Kenwood Audio Players & Recorders
Replaced battery on my remote control and it does not work. does it needs to be re-programmed again?
Use this Procedure for Vehicles with
Driver Information Center Buttons
This information is in your Owners Manual in the
Drivers Information Center Section.
1. Insert Key and turn to ON position so you can access Driver Information Center
2. Press the vehicle information button until
PRESS TO RELEARN REMOTE KEY displays
3. Press the set/reset button until
REMOTE KEY LEARNING ACTIVE displays
4. Press and hold the lock and unlock buttons on the first keyless remote at the same
time for approximatley 15 seconds. A chime will sound indicating that the remote is
programmed.
5. To program additional remotes at this time repeat step 3.
This vehicle can have a maximum of eight remotes programmed.
6. To exit programming mode turn key off and remove key.
Test remote(s).
Use this Procedure for Vehicles without
Drivers Information Center Buttons
To access this display, the vehicle must be in Park (P) with key in the on position (as far
as you can go without cranking engine)
1. Press the trip odometer reset stem until RELEARN REMOTE KEY displays.
2. Press and hold the trip odometer reset stem for three seconds.
The message REMOTE KEY LEARNING ACTIVE will display
3. Press and hold the lock and unlock buttons on the first keyless remote at the same
time for approximately 15 seconds. A chime
programmed.
4. To program additional remotes at this time repeat step 3.
5. To exit programming mode turn key off and remove key.
Test remote(s).
Good luck and hope this helps, you may have to reprogram. merry Xmas
Dec 24, 2009 | 2007 Chevrolet Tahoe
I just brought universal remote control it an 8 way diital slx rc050 i can get it to pair with my accousic solutions sp 101 amp have you got any codes that would work for this please
try this if you need the manual let me know. (PLEASE rate if it was helpful)
If you are programming the remote for a brand/model that is
not listed in the Popular Brand List or the Direct Code Entry
(e.g. Wharfedale, Acoustic Solutions etc), it is recommended
that you use the Learning Mode (go to section 4).
Follow the steps below to program your remote using the
learning function.
1. Press and hold the device key you wish to learn for 3 secs.
The LED turns ON when the key is pressed but turns OFF
after 3 secs indicating that the key can be released.
2. Release the Device key, LED turns back ON.
3. Press and release the RECORD key, the LED turns off
when the key is pressed and turns on after release, the
remote is now in the learning mode.
4. Press and release the key on the RC050 that you want to
learn to, the LED will blink once and then remain ON with a
lower brightness to indicate it is ready to learn.
5. Face the head of RC050 to the head of your original
remote control, leaving a gap of 5cm (2”).
6. Now press and hold the original remote key (the teaching
key), do not release this key until the LED on the RC050
this indicates an error. Repeat steps 4-6 to correct the
error.
7. LED remains on, repeat steps 4-6 for other key functions to
be learned.
8. Press and release EXIT key to exit learning mode at any
time, the LED turns off.
9. If no keys are pressed for more than 15 secs while in
this mode, the remote exits the mode and the LED turns
OFF
good luck
4. Learning Mode
Dec 18, 2009 | Televison & Video
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
Dec 07, 2009 | Televison & Video
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
Hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Remote Codes 506 or 127
Direct TV (Remote Model RC-64RB)
Remote Codes 11144, 11240, 11331, or 11610
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
Jun 02, 2009 | Syntax Olevia 226T 26 in. LCD Television
Cant get remote to setup with sattelite reciever or my dvd player
Searching for your code press the tv key once, Next press and hold the set up key until the led blinks twice, then realease the set up key.
Now press numbers 9-9-1 the LED should blink twice
Point the remote at the tv and slowly alternate between pressing the power and tv keys stop when tv turns off. Now this is based on the information if it is a Kenwood remote RC RO720... if not may I get the make and sat info and may be more helpful to you....Thank you
Feb 06, 2009 | Kenwood RC-R0720 Remote Control
Att uverse remote won't turn on yamaha reciever
Do an automatic search for your code.
  1. Turn on the device you wish to program
  2. Point the remote control at the device
  3. Press and hold the mode key (i.e. tv, dvd or aux) you want to program
  4. Without releasing the selected mode key, press and hold the OK key simultaneously
  5. Release both the mode key and the OK key -All the modes keys will flash twice indicating programming mode
  6. Enter 922 by pressing the number keys on the remote control -The selected mode key will flash twice indicating correct entry (for anything other than AUX go to step 7, for the AUX mode searching only, press and release the play key then press 1 for VCR 2 for Receiver/Tuner 3 for Amplifier or 4 for Home Theater In The Box (HTIB) - The AUX mode keys will flash twice indicating correct entry)
  7. Press and release the PLAY key, every time you do this, autoserach will try a different code, continue to do this until your device turns off. (if you weren't paying attention and you miss it, the REW key can be used to go back through the codes one at a time, and the ff key can be utilized to move forward through the codes one at a time.)
  8. To save the code press the ENTER key (below the number 9) then press the exit to return to normal operations. (the selected mode key should flash three times
  9. Turn you device on by selecting the appropriate mode and power.
Jan 19, 2009 | Yamaha HTR-5940 Receiver
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Philips MCD716
1.Press DVD "OPEN/CLOSE" key (RC (remote Control) or main unit) to open the DVD tray (note:if no disc on tray,then you have not to open it);
2.Press RC "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not entering the sub-item );
4.Press RC numeric key sequentially 811502(enter code, however no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
Nov 23, 2008 | Televison & Video
Kenwood Remote Control RC-150 p/n:A70050405 Logo
76 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
