Wheel noise in front right on 1998 gmc jimmy - Computers & Internet
5 Suggested Answers
SOURCE: 1998 Jimmy Grinding noise
Just had the same problem left front wheel bearing was gone in mine hope this helps should get it looked at rite away front wheel will seize and cause a lot of other damage
Posted on Mar 17, 2009
  • 177 Answers
SOURCE: 1996 gmc jimmy started making
Sounds like your front axle is trying to engage but does not engage fully.check your vacuum going to the t-case switch and then if that is ok check your vacuum at the front axle actuator.It is located under the battery tray.
Posted on Dec 06, 2010
  • 1168 Answers
SOURCE: 1998 gmc jimmy you here
Hello Bj.
This is a common issue with the Jimmy's in that year.
Because you can hear the shift motor it likely works.
The problem is likely at the front differential. There is a vacuum actuator that has a cable that pulls on a lever which engages a clutch inside the differential tube.
This vacuum originates at the engine, goes to the transfer case. On the transfer case the is a vacuum switch which then directs the vacuum to the vacuum motor when 4x4 is called for.
You will need to check for vacuum at this motor which is located on the right front engine compartment down low. Tricky to get to but not impossible. Follow the cable from the right side of the differential if you can't locate it.
If no vacuum, trace it back to the leak. If no leak, the vacuum switch on the transfer case may be bad.
If vacuum is there, which I suspect it is, replace the vacuum motor and cable assembly.
There you are, if you have further questions, please ask me here.
Thank you for using FixYa.
Posted on Jan 16, 2011
rustfarmer
  • 5316 Answers
SOURCE: I have a 1999 GMC Jimmy with a popping noise at the front right wheel
Could be one of a dozen or so things, such as ball joint, tie rod end, shock strut, loose caliper, cracked rotor, loose wheel, loose fender/bumper bolts, others also. Have it checked at front end shop if you don't know how.
Posted on Jan 29, 2015
Jan 29, 2015 | GMC Cars & Trucks
97 jimmy wont go back to 2 wheel drive
Check everything in that right front driveline. Could have a problem that when the four wheel drive puts some tension on it, it stops making noise.
Mar 17, 2013 | 1997 GMC Jimmy
Ok I just bought a 1998 gmc Jimmy and this is my problem when your driving down the road it has a pretty bad vibration but when you turn to the left (only) it goes away any ideas on what that could be?...
Sounds like a belt is seperated in the front left tire...your local tire store can inspect this for free...your next check would be alignment...tough chuck holes can cause mis-alignment and unecessary tire wear...Hope this helps....(Front left wheel bearing does this too, but a slight grinding noise is also present)
Feb 16, 2011 | 1998 GMC Jimmy
1996 gmc jimmy started making noise sounding like it is is right front was told need to replace wheel hub which was done. Still making the same noise in 2 wheel drive. when you push button for 4 wheel...
Dec 06, 2010 | 1996 GMC Jimmy
What is the torque setting on a gmc jimmy 1999 front wheel hub 36mm nut.
the torque for the outter axle nut at the wheel for a 1998 gmc jimmy is 103 ft lbs. hope this helps.
Jun 15, 2010 | 1998 GMC Jimmy
Vibration from right front end
check wheel bearings , loose ball joints steering idler arm...
Aug 09, 2009 | 1998 GMC Jimmy
1998 GMC JIMMY 4 WHEEL DRIVE, NOISE COMING FROM FRONT WHEEL AREA
it is the u joints on the front drive shaft ,i had the same problem and like too never found it!!!
Apr 20, 2009 | 1998 GMC Jimmy
Mar 17, 2009 | 1998 GMC Jimmy
Like a tire rubing noise in right front on 97 gmc jimmy 4x4
If noise will go away when you turn wheels a different dirrection you need a wheel brg. hub assem.
Jan 01, 2009 | 1999 GMC Jimmy
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
