Error 3
I have turned on my hardrive but my computer is unaible to find the harddrive and says error3
  • 27 Answers
Unfortunately hard drives break. It could be a head that's broke or that it can't read the MBR. (Master Boot Record) If that's corrupted then it's a gonner. There are places where equipment is available to repair it but, if you've got your files backed up just get a new HDD and reload your Software. (Windows and files.)
Posted on Nov 18, 2013
4 Suggested Answers
fire sine
  • 382 Answers
SOURCE: My Computer doesn't recognize Ion 320 GB Harddrive
Well if its lighting up, then the drive is receiving power, or the enclosure atleast. Forget that case, extract the drive, and seek out something more reliable and more solid. Preferably an aluminum enclosure with no fan.
seek out Weibetech.
Posted on Oct 23, 2007
SOURCE: My Computer doesn't recognize Ion 320 GB Harddrive w/Tri select
This isn't a solution but might help...
I have the same drive... with mine it recognizes sometimes but usually freezes my computer when I try to write to the drive. I thought it was the actual hard drive, but that works fine when installed in my tower... I now notice that one of the small components, component L14, is actullay missing a corner!!!! Like it chipped off! I'm blaming that. It seems to be part of the usb/firewire section of the mainboard. I'd like to replace it... does anyone know what that component is?
here are some photos:
www.belowmemusic.com/ion
Posted on May 31, 2008
  • 60 Answers
SOURCE: 500g harddrive
It broken. if you want your data back youl have to spend alot on data recovery.
Posted on Dec 25, 2009
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
EMachines Recovery Discs
Hi Sandysue, As I understand your problem, 1. The error could be caused by: memory, video, hardrive or drivers; 2. Windows by asking you to run CHKDSK /F has detected a possible problem with your harddrive; 3. It is possible that the reason you cannot go to DOS mode is because your harddrive is formatted in NTFS and not FAT332. There are a couple of ways on how to go about this but all would require that you have access to second PC: 1. Run a third party software (BartPE) that you will have to boot from your CD Drive or USB and run a disk checking utility; 2. Remove your hardrive and install it as a secondary master in the 2nd PC and run chkdsk or scandisk; 3. Remove your hardrive and install it in an external HD enclosure and connect using USB to the 2nd PC and run chkdsk or scandisk; 4. Remove your hardrive and install it either USB or as secondary master to the 2nd PC. Copy all your important files to the 2nd PC, and repartition/reformat. Reinstall to the eMachine and reinstall Windows. There is a possibility that even if you were able to run CHKDSK or Scandisk eventually your best bet would still be #4. If you have gained access to the inside of your eMachine PC, it would also be a good idea to remove/reinsert any cards and the memory stick(s). A little housekeeping would also be nice. I hope that this be of some help and pls post again how things turn up or if you need further information. Goodluck and kind regards.
Jul 31, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Compaq Presario S3040SE PC Desktop was working fine. when i turned it on next day screen says operating system not found. restart. now monitor wont kick on and hard drive light doesnt come on. only power...
Normaly when you get the error that the operating system cant be found, it is a indication that the hardrive has either gone bad, or somehow some of the system files got deleted. I would say though since the hard drive light wont come on it could be the hardrive has shut down completely. But you still should see the company image of your computer when you start it up, (the bios screen)
A bad hardrive would be my first guess, 2nd problem if its not your harddrive would be a new power supply.
Dec 31, 2009 | HP Compaq Presario S3040SE (DF222AR#ABA)...
IT TURNS ON BUT SHUTS RIGHT BACK OFF CAN SOME HELP ME FIX MY PLAYSTATION3
Try removing the harddrive, and then turning it on..
If it will stay on without the hardrive then the hardrive has gone bad..
If it still wont stay on please reply to the post with any beeping noises it is making,or any other error conditions it shows...
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
Looking for visuals to assist me in removing my harddrive-below
verry eassy to do turn laptop over remover cover from hardrive there will be screws holding hardrive in place remove them, push hardrive back till it stidesout of socket and lift it out.i run acers do it all the time. your hardrive cover on bckside will be aboyt 4 inchs long about 3 wide a couplescrews holding it in place.IM me you need assistance ok glad to help
Jun 29, 2009 | Acer TravelMate 2423WXCi Notebook
Hardrive not working
Try the harddrive in an external case. If that dosent work the board on the drive is fried, and youll have to find an exact harddrive and transfer the board.
Jan 11, 2009 | CybertronPC AMD Sempron 2400+/ 128MB DDR...
Playstation cannot start
your harddrive may be failing, When you turn on the PS3 the harddrives parttion sector is read ...this is where info for your desktop and icons is kept. if your hardrive has bad sectors it will result in an erratic mannner such as what you are describing. goto a local gamestop or friend and get another harddrive. insert it into your ps3 and see if that works...but remember all info get deleted off the hardrive
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
500g harddrive
Jul 24, 2008 | Western Digital My Book Essential Edition...
Help
try to format the hardrive in the ps3 system if you cannot access the option in the ps3 in formatting your hardrive you can remove the harddrive from your ps3 and connect it on the PC and format it there
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
seek out Weibetech.
Oct 15, 2007 | IOGear ION (GHD335C160) 160 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
