Error 52 on Zanussi
Any idea what error 52 means,I've checked all the error code lists I can find and error 52 isn't on any of them
  • 1 more comment
  • MaxiTech
    MaxiTech Nov 16, 2013
    This website may be helpful for you with further information about error codes on Zanussi washers
  • MaxiTech
    Add a Commenthttp://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3068-zanussi-washing-machine-error-codes.html
  • MaxiTech
    websitehttp://www.ukwhitegoods.co.uk/help/fix-i...
    Problem Solver:
  • 15 Answers
I believe it means
"no signal from the motor tachometric generato"
Which means Tachometer (tacho) coil on the motor may be faulty. This coil reads a magnet as the motor turns to detect the speed that the motor is spinning at and this in turn allows the electronic controller to set the motor to revolve at different speeds for the various program options.
Posted on Nov 16, 2013
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
http://www.serviceforce.co.uk/pdfs/U21039.pdf
online manual
Posted on Oct 31, 2008
  • 25 Answers
SOURCE: e10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Posted on Feb 28, 2009
  • 44 Answers
SOURCE: zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Posted on Mar 21, 2009
kevin000
  • 1847 Answers
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Apr 24, 2017 | Jeep Cars & Trucks
Zanussi zwn 6120 l washing machine Error code 5 red 1 green
Your washing machine show the error code E51 what means faulty electronic (triac short circuited). Replace PCB.
A good idea is to check the motor, which in practice can cause this failure (shor circuit motor winding) and sometimes is necessary to replace the electronics and motor and than is question profitability of repair.
Dado
May 07, 2015 | Zanussi Washing Machines
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
Zanussi washing machine zwf14581w . err e40
Hi.
Error 40 means : "Door Error"
When you get error 40 it is usually because of a defective door interlock.
Try disconnecting power for five minutes. If the error comes back the parts to be tested are door interlock, wiring or main PCB. The defective part must be replaced. Parts and quote on repair can be obtained contacting Zanussi customer service at the number listed on the owners manual.
Regards.
Ginko
Aug 20, 2011 | Zanussi W1042W Front Load Washer
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Error code f 18 on hotpoint wd640 ? any idea Everything seems to be working except drium isn ot turning, i hace checked the obvious like the belt.
F18 usually indicates a communication error according to Hotpoints error code list, if you have tried everything that you can and it still does not work, then you are going to have to call an engineer.
Dec 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
