Question about Champion 26 in. D-HBTC Free-Standing Dishwasher
Legion comb tilt skillet pilot lights but burn won't
    Champion:
  • 208 Answers
Tilt switch not engaging
Posted on Nov 18, 2013
Replaced gas valve and pilot along with ignitor control on vulcan tilt skillet
Could you please describe the problem you are having a little better?
Dec 03, 2012 | Kitchen Ranges
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
Patio heater phs won't ignite
Hi, First check if you have a full tank and that the pipes are clear of any insects, water or debris. Next see if you have a spark where the pilot is, if you can hear the piezo clicking but cannot see a spark then check the lead. Sometimes the lead can get loose and short out lower down and prevent the spark from reaching the pilot. You may need to take the lead out to fully check. If you have a spark and gas is reaching the pilot then check the tilt switch, if faulty it can turn the gas valve off. To check you can just short out the tilt switch, found this site very useful patio heater problem solving.
Oct 01, 2011 | Endless Summer 2009 Open Flame Patio...
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Frontgate patio heater, serial number 01A02 0023562, model number SRPH02, cust number SHCDPH, pilot light won't light (checked gas tank already)
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
May 18, 2011 | Frontgate Stainless-Steel Outdoor Patio...
Groen tilt skillet 750 mv control
you need to check the generator in series with flame present. remove one wire from gas valve.put 1 of your meter probes under gas valve terminal where you removed one lead from powerpyle generator.put generator on other probe anything over 600 mv and your generators is ok under replace
Jan 14, 2009 | Cozy Enclosed Front Console Heater 20,000...
Need electrical cord for general electric skillet
Call this number: 877-207-0923. You will be able to order the replacement part.
Nov 22, 2008 | GE 106749
Rival electric skillet # S16g-CN
I have just taken apart the probe / thermostat of this model for a friend. I am an amateur, but it is such an amazingly SIMPLE piece of equipment (in the non-digital, i.e. mechanical thermostat model I'm looking at, that it is clear that the light will be "on" if the thermostat is sending electricity to the heating element, WHETHER OR NOT the element is broken or even connected to thermostat: In other words, if the light is not going on with thermostat knob in any position but OFF, the problem is with the thermostat: The pilot light goes on even if thermostat is NOT PLUGGED INTO the pan; when functioning properly, which one can observe on working pan even w/o taking it appart. But if you have digital model, this will be of less sure use to you, tho the way two yellow wires go to pilot light INDEPENDENT of power returning from pan itself, it suggests the same may be true with all their models.
Nov 29, 2006 | Rival S16 Electric Skillet
Champion 26 in. D-HBTC Free-Standing Dishwasher Logo
74 people viewed this question
Top Champion Dishwashers Experts
bengsoon Neo
Jude24
Trevor Turner
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
