Question about Health & Beauty
Sterling sapphire 2 scooter does not charge from the tiller but will charge when connected to batteries
3 Suggested Answers
  • 118 Answers
SOURCE: sterling sapphire 2 4wheel scooter
Larry,
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
Posted on Nov 27, 2008
  • 103 Answers
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Posted on Jul 23, 2009
My sterling sapphire bleeps 8 times and i have done all the manual said, but it won't move.
You need to consult your owners manual. Flash codes/bleeps
are explained in there.
Feb 14, 2015 | Health & Beauty
What fluid is used in mobility scooters electronic brake for sterling sapphire
There is no fluids in either brake on on these,there is two braking systems,both electronically operated .when stopping or slowing up power generated in motor is returned to the battery .this rapidly retards the motor dynamically braking the scooter,a fraction of a second after stopping the electric parking brake is applied by removing its 24volt supply,this is the click you hear when starting or after stopping the scooter.the only servicing reqd is to dust of the casing of the electromagnetic parking brake. do not dismantle it,or oil it.to test try to push scooter,if it moves easily when NOT in freewheel.replace it.
May 23, 2014 | Health & Beauty
How do i fix a throttle on a sterling sapphire mobility scooter
The Sterling Sapphire is not sold in the USA so, you may want to verify this information with a local technician however; 7 flashes or beeps is commonly a throttle issue. When the problem starts and you have been driving for awhile, ensure the throttle lever is in the stop position, turn off scooter, wait 10 seconds and turn scooter back on. If that does not clear your problem: There should be two set screws (very small) that you can tighten with an allen wrench on the throttle lever. Make sure those are tight.
If this is a continuous problem, you may need a new throttle potentiometer.
Apr 29, 2014 | Health & Beauty
Wrong question previously asked... The correct one is fault with: Sterling saphire mobility scooter 10 short bleeps and two long ones?
Depending on which way the s-drive controller is programmed, this could mean one of 2 things:
Firstly, low battery voltage. Check batteries and all associated connections, and make sure the scooter is fully charged.
Secondly (and most likely) the 2 bleeps means you have an issue with the Motor, and / or its connections. Check motor brushes, and the connections under the scooter, which is usually a white plug underneath the scooter, near the rear wheels, and ensure no muck or water has got into the connections. If the brushes and connections are ok, then chances are you need to replace the motor.
Regards
Apr 25, 2014 | Health & Beauty
Sterling sapphire 2 4wheel scooter
Hi 9 beeps .is a solenoid brake trip fault ( CHECK PARKING BRAKE for BAD connections on motor & check all wiring connections.cheers
Nov 08, 2017 | Health & Beauty
I need help to get a sterling sapphire ls user manual please can you help me to get one
contact Sunrise Medical @ (800) 333-4000
ask for tech support see if they can help you Hope this helps
May 07, 2011 | Electric Mobility Power Electric Scooter...
Charging sterling elite 2001 scooter batteries
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Larry,
Oct 27, 2008 | Health & Beauty
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
