Sliding van door adjustment mercedes
Bottom door bracket needs replacing. How does it fit and how do you adjust the dooor
  • 113 Answers
Wrong category, Tony!
Posted on Nov 16, 2013
Sliding door on my 1996 ford aerostar van has completely come off track and all attachments from top to bottom are broke. the bottom piece is the only thing still attached all brackets are bent and door...
Check around the car wreckers that specialise in ford and ford vans for a complete assy. Some wreckers, if they want business, may even fit the door for you at a reasonable price.
Aug 24, 2013 | Cars & Trucks
How to tighten serpentine belt on 2003 mercedes e320
Most serpentine belts are adjusted on the idler pulley. Undo the nut holding the pulley on just enough to allow the pulley to slide up or down At the rear if the pulley bracket look for an adjuster screw parallel to the pulley screw this up or down to adjust the tension. When done retighten the pulley nut.
Apr 27, 2013 | Cars & Trucks
2005 Honda Odyseey van sliding door continues to trip breaker and not work.
make sure the cable is on the track and not running next to it dragging a heavy load on the system this happens when the door if push close while the motor is trying to run it
Aug 08, 2012 | 2005 Honda Odyssey
Adjust dr side door
If you can grab the end of the door and lift on,and there's movement, what you need is the door hings bushing, most all auto parts sell this as a kit, cost about $6.00, the only adjustment you will have will be at the striker bolt, that the part where the door latch, latches to, to hold the door close, it unscrews and it will have some adjustment, but not much.There not adjustment for door hing.
Jul 08, 2010 | 1999 Chevrolet Venture
Ksrg25fkss kitchenaid refrig door needs height adjusted up
Have you looked at the mounting bracket for the lower hinge to see if it can be adjusted up. If not and there is as mush as 1/4 to 1/2" adjustment i suggest that you get a spacer with the inside diameter the same as the hinge pin or a tiny bit bigger and cut it to the size you need , then support the door up to a point that the bottom pin is not bound, remove the lower bracket and hinge pin, put the sleeve you cut on the hinge pin and reinstall the bracket.
Jul 28, 2009 | Refrigerators
The automatic sliding door leaks, rattles, and doesn't always shut all the way. Have to give it a little exterior ''hip action'' to get the rear of the door to latch shut. Also sometimes it mysteriously...
i had an aerostar with the same proble, easy fix........there is a catch just inside the rear part of the car where the door closes, it needs adjusting, its about half way up, you can see it if you open the door fully, look just inside the door space , where the door fits into place....you will see 3 hex screws, there is also an adjustment catch on the door itself
Jul 22, 2009 | 2003 Ford Windstar
Broken door handle - 2001 Nissan Quest SE
first you van order parts at discount from tascafordparts.com.
quest & mecrury villager are the same vehicle made at the same assembly plant. good luck to all. If you were in detroit area, I wold help you.
Trim Panel —Sliding Door Removal
  1. Remove the sliding door trim panel finish panel.
532ac84.gif 2. Remove the sliding door trim panel 2965fbe.gif Latch Remote Control —Sliding Door Removal
  1. Remove the rear sliding door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. If equipped, disconnect the sliding door power door lock actuator electrical connector.
  1. NOTE: Mark the position of the sliding door rear latch cable adjusting bracket before removing the bolt.
  2. Disconnect the sliding door rear latch cable.
  3. Remove the bolt.
  4. Remove the sliding door rear latch cable adjusting bracket from the latch remote control.
  5. Disconnect the sliding door rear latch cable from the latch remote control.
  1. Remove the 4 sliding door front latch bolts.
NOTE: If necessary, transfer parts to the new sliding door latch remote control.
Remove the sliding door latch remote control.
  1. Remove the bolts.
  1. Remove the sliding door latch remote control.
Handle —Exterior, Sliding Door Removal
  1. Remove the sliding door latch remote control. For additional information, refer to Latch Remote Control—Sliding Door .
  1. Remove the sliding door exterior handle.
    1. Remove the nuts.
Mar 08, 2009 | 2001 Nissan Quest
Alternator bracket fanbelt slippage
fan belt adjuster locking bolt & nut
Jan 05, 2009 | 1999 Ford Escort
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
