Question about TESORO Building Materials
What is tereso flooring - TESORO Building Materials
How do you remove the lower center console on a 2000 Olds Intrique
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
Jun 10, 2015 | 2000 Oldsmobile Intrigue
How do I install a floating floor
Floating means you do not use Glue...You should put the mat down that they recommend over the sub floor prior to installation
Feb 15, 2015 | Pergo Accolade Castlewood Maple Laminate...
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Preliminary Procedure
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
What is Radiant Floor Heating System anyone can tell me?
I think the concept behind the Radiant Floor Heating System is that Installed tubes or heating element, which contains water beneath the floor, which warm our floor. For more information about Radiant Floor system you can check this site.http://www.ps2i.biz/
May 28, 2013 | Mountain Plumbing Plumbing
What are the advantages of cork flooring?
Cork flooring has many advantages. Cork flooring is comfortable and easy to walk on, the cellular structure of cork makes the floor very durable which can absorb sounds and blows making the cork floor a great pick for apartments and condominiums.
Feb 06, 2013 | Building Materials
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
Which is the largest building in india
List of tallest buildings in India
  • The Imperial, Mumbai - 60 Floors
  • Ashok Towers 1, Mumbai - 53 Floors
  • Planet Godrej Mumbai, 51 Floors
  • Shreepati Arcade, Mumbai - 45 Floors
  • RNA Mirage, Mumbai - 41 Floors
  • Belvedere Court, Mumbai - 40 Floors
  • Oberoi Spas, Mumbai - 40 Floors
  • Kalpataru Heights, Mumbai - 39 Floors
Aug 20, 2010 | Computers & Internet
How can i find out my parking brake adjustments on my 2003 ford escape?
Parking Brake Cable Adjustment Vehicle with low series floor console
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
  1. Remove the floor console rear finish panel.
    1. Apply the parking brake.
Vehicle with high series floor console
  1. Remove the floor console finish panel.
All vehicles
  1. Remove the adjustment nut clip.
  1. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
  1. Confirm the parking brake is applied.
  1. Install the adjustment nut clip.
  1. Install the floor console rear finish panel.
  1. Install the floor console front finish panel.
    • If equipped, install the manual transmission shifter knob by turning clockwise.
Jan 21, 2009 | 2003 Ford Escape
Building Materials Logo
67 people viewed this question
Top TESORO Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a TESORO Building Material Expert? Answer questions, earn points and help others
