Question about Acer Computers & Internet
Acer al1951 I have an AL1951 Monitor as a second display to my ACER Laptop. Very frequently but not always the volume setting pops up on the screen and stays there. Sometimes it is just a few seconds with a frequency of once every 2 minutes, sometimes it is continuously and renders the monitor useless. I only use a RB connector Ideas?
    New Friend:
  • 15 Answers
All switches on monitor needs replacing
Posted on Nov 16, 2013
skotkolr
  • 558 Answers
SOURCE: acer monitor auto config screen pops up every 5-10 seconds
hope you got an answer
Posted on May 02, 2008
russolini
  • 47 Answers
SOURCE: Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
Posted on Jun 10, 2008
  • 10 Answers
SOURCE: The Volume Screen on my monitor keeps popping up
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Posted on Mar 24, 2009
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Posted on Jul 18, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
I have a new Acer Aspire ONE D257-13464 I have Windows 7 Starter on it. I am having problems with my projector and the Acer mini laptop. When I am doing a business presentation I can not use it in the...
Charles - does the laptop have an alternate function button that allows for different displays? Similar to the presentation mode, this will manually tell the laptop to use either the native screen, an extension screen (the projector or monitor) or both. Typically this is triggered with the Function (Fn) button and maybe one of the F7 keys at the top. You'll see writing on it that will say LCD/CRT or have a little box like a monitor. Let me know if this helps!
Oct 24, 2017 | Acer Aspire One PC Notebook
Acer al1951 monitor not refreshing
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 27, 2011 | Computers & Internet
I have hooked my Acer 1912 monitor up to my toshiba laptop as a second screen. When I select a resolution of 1280 x 1024, the display on the monitor slides over five inches to the right and I only see half...
Friend,
On the monitor go to settings and shift the screen to the left till the display is correct. However, please check for other resolutions after you have shifted. May be the monitor is not geared up to take on 1280 X 1024. Check that as well.
Aug 25, 2010 | Acer AL1912 19" LCD Monitor
Acer Aspire One, Screen turns strip-y grey/white
hi there, my sisters dell laptop does the same thing. My best guess is that a hard knock on the graphics card and knocked a few pins out of it. This is something that a average person can not do. My suggestion is to bring it to a computer shop and tell them that you think it's the monitor connections.
Jan 31, 2010 | Acer Aspire One PC Notebook
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer Aspire 5050-3242 Notebook
Acer AL511
Hi...there,
I thinks your OSD Setting time set to high... Open on screen display on your monitor, go to OSD Settings and look for OSD hold time and setting to 10 seconds. If that doesn't work...reset to Factory Resettings.
Jan 12, 2009 | Acer AL511 15" Flat Panel LCD Monitor
Acer Monitor
Give both the up and down buttons a tap. Sometimes even if the button comes out, the physical switch behind it dosnt.
Hope that helps.
Mar 31, 2008 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
