Question about Nikon N70 35mm SLR Camera
N70 FE E error in LCD and view finder - lens locked properly
I have a Nikon N70 with Nikor D lenses that I purchased in the late 90s. The camera never gave me a problem until this week. I was on vacation taking pictures, on the fourth day with an SB22 flash. Through the fith or sixth picture I received an FE E error in the LCD and in the view finder and the shutter would not depress. The lens was locked as required and the flash was on TTL. The camera appears to work in Aperature priority and manual modes but has the same issue in S mode. The batteries were replaced but the battery indicator flickers in the LCD. Any ideas?
  • Sextone Oct 09, 2007
    Unfortunatley the lens was locked in the highest number and I still have the same error.
Yes, the error is due to your lens not being set to highest F number. Solution : set lens to the highest number ( f 16 or f 22 ) and lock it in ( on the lens ). Your camera will work find now.
Posted on Oct 08, 2007
SOURCE:
Diaphragm stuck
It's serious enough that you will not be able to fix it yourself. You should send your lens to Nikon for a repair estimate. You will find information on the Nikon USA website regarding where your closest Nikon Repair Depot is located and return procedures.
May 29, 2013 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
How do I access the macro function on the nikor 35- 70 1:2.8 D Lens?
Pull the lens all the way IN (i.e. zoom to 70mm) then press the MACRO LOCK, and then adjust focus using the macro ring.
Feb 08, 2011 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
View through viewfinder is dark, looks like dark sunglasses over lens. 24mm lens indicates fE E on lcd code. Shutter will not function or lens will not automatic focus. Switch to 70-300 lens, view finder...
Sounds like the aperture control actuator ring in the camera body is not opening the aperture diaphragm blades fully a repair quote and decide if a different body upgrade may be a better option
May 29, 2017 | Nikon N80 35mm SLR Camera
User Guide for Nikor 2.8 70-200 vr Lens
The manual can be found on Nikon's website or click on the following link: http://www.nikonusa.com/pdf/manuals/lenses/AF/AFSVR70-200_2.8G_(80)05.pdf
The manual is a combination of several languages all bundled together. The English portion is from P14 - P21.
Hope this helps.
Andrew
May 15, 2010 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
''New'' Lens will not Focus,how can I fix this problem
Try Nikon's website for connection to their Technical Support. www.nikonusa.com
Jun 11, 2009 | Cameras
Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
Jun 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Feb 10, 2009 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Lcd preview blank d200
you cannot "Preview" shots on the LCD screen with the D200. There is no Live View function. Newer models such as D300 and D90 offers such a feature.
Nov 10, 2008 | Nikon D200 Digital Camera with 18-200mm...
Sigma 170-500mm APO lens on Nikon D50 won't autofocus or shoot
When you get a flashing EE, it means there is an Eror somewhere. Most cameras have a botton you press to reset it. Usually it is the battery check button. Try that. Also try taking the lens off the camera, unlocking the aperture ring, remount the lens and then lock the aprture ring to the minimum F stop. I think this should solve the problem.
Aug 06, 2007 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Nikon N70 35mm SLR Camera Logo
472 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
