Question about Compaq Microsoft IntelliMouse
Mouse Problem My mouse suddenly only lets me move my cursor to the left and right not up and down. what's happened? Please help! I had to go to the library 7 miles from my house to type this because i couldn't even get to my search bar
  • McREO Mar 06, 2009
    My system boot but i use an optic mouse but it can not move for me to log in so i just can't use my system. i need solutions.
  • 102 Answers
If this was a ball mouse the I would have said the spindles need cleaning. I think there may be a problem with the optical sensor. Since mice are 10 a penny couldn't you try another one? Also you should learn the keyboard shortcuts, there is very little you can't do with the keyboard that you can do with a mouse.
Posted on Oct 07, 2007
Mouse does not move cursor, button works though
It could be the light, but have you tried using a different less reflective surface?
Feb 17, 2014 | Quill AirObic Mouse - Right / Left Hand
Dont know how to copy and paste
Let's use an example Debbie
-> don't know how to copy and paste
Put your mouse cursor on the d in don't.
Press the left mouse button, and hold it down.
Now move the mouse cursor across the entire sentence, moving to the right.
Stop at the letter e in paste.
Let go of the mouse button.
The sentence will now be highlighted in Blue.
Now press, and hold the CTRL key, and tap once on the c key.
[Small case letter -> c ]
Put your mouse cursor, where you want to paste what you have copied.
In your browser address bar, or whatever.
(Address Bar: The box at top that has the URL in it.
Starts off with www, or http:// )
Now press the CTRL key down again, and this time tap once on the -> v key.
c key is the Copy key, v key is the Paste key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 16, 2013 | Dell Inspiron 2200 Notebook
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
Sidebar has suddenly moved to side affecting size of screen. How do I return it to bottom???
You are probably talking about the windows Task bar that normally resides at the bottom of the screen:
Two ways of moving this task ba, to top/bottom/letft/right position of the display:
  1. Move the cursor on a blank/inactive area on the task bar, usually in the largest blank area towards the right, click and hold the right mouse button and drag the Task bar to the bottom of the screen.
  2. Go to the Task Bar 'Properties' (You can get this context menu by clicking the left mouse button after putting the cursor on a blank/inactive area on the task bar) and change the 'Task bar location on screen' option.
Hope it helps: let me know how you go.
Dec 17, 2010 | Toshiba Computers & Internet
I have a corded mouse on my PC which sticks and flys to the right
A corded mouse can be either an older style with a ball, or newer with the red light. I have found you can take the ball out and clean the rollers inside with tweezers, they eventually get gummed up with lint and such. If it is a red light, most often my problem is a dog hair or something blocking the light. Tweezers work.
Oct 01, 2017 | Microsoft IntelliMouse
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
Cordless mouse cursor frozen
it is absolutely broken even u can click right and left but the red light is off it is like half dead machine, i advise u get another one...
Mar 03, 2008 | Logitech Cordless Optical Mouse for...
Logitech mouse problem
sounds like you have reverse mouse enabled  go into the control panel find the properties for you mouse, this should be a check box you can disable.
Oct 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
