Hello we have bought this surround sound system and cannot connect it so that the speaker works fro the TV (But the speaker is functional). We think there is a connection problem. The manual shows only one audio connection on the TV the speaker is connecting to but we have four sets of connections for external speakers on our TV. IS there any way around this?
-   Apparently there is no Audio Output connector to plug in external speakers. Am I right ?-   Guest
Oct 26, 2008
-   I have the same problem. This Proscan has several RCA input jacks, but no RCA output jacks. There is one jack labeled "Coax digital out," but not a pair of rca outputs as on almost every other TV I've seen.
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers.
If I have misunderstood you then please comment before rating badly
what type of surround sound speakers are compatible for an hitachi 42LDF30U A tv? what would you...
(More)
what type of surround sound speakers are compatible for an hitachi 42LDF30U A tv? what would you recommend.
My poaroid flatscreen lcd television has a green vertical line running down the right side of it. Is...
(More)
My poaroid flatscreen lcd television has a green vertical line running down the right side of it. Is it possible to fix this?
I have a 19 inch LCD 19880HDF tv. Every now and again the screen goes fuzzy and makes a crackling...
(More)
I have a 19 inch LCD 19880HDF tv. Every now and again the screen goes fuzzy and makes a crackling noise. What's the solution please. If tv is left off for a few minutes it goes away.
