Question about Moultrie MFH-DGS-100V2 Digital Camera
Camera will not work with sd card
The camera works great without a SD card. As soon as you put a card in and turn it on the camera will lockup. When we try to set up the camera none of the buttons will work.
  • 5 more comments
  • Little Bo Mar 09, 2008
    When you use an SD Card, the indicator says SD Card Locked and the camera will not work.
  • ryes1 Jun 17, 2008
  • dariete2004 Aug 12, 2008
    When i take photos and try to look them in Pc only simbols appear as folder´s name and not numbers or letters and fotos dont appear.
    I used 3 new cards and 1 who work in a Digital camera and not in my moultrie i 40.
    Thx
  • Anonymous Sep 22, 2008
    will not power up
  • gignac02 Feb 03, 2009
    witch pin on sd card is lock pin?
  • Anonymous Mar 19, 2014
    camera working without sd card but when put in camera wont work
  • Anonymous Mar 27, 2014
    we have two identical cameras with the same sd card. with one camera as soon as you put the sd card in, it says: sd card locked. this doesn't happen with the other camera, nor after swiching the sd cards. so the problem is with that one camera. is there a solution?
Had the same problem, blew out the card slot with air and fixed it. Apparently poor contact points with the card.
Posted on Jul 27, 2008
The problem is with the card lock reading pin on the PC board. Sometimes the contact isn't good, so it brings the card locked message. You need to open the camera up and play with the contact pin so it make permanent contact with the casing. This way, it will always see an unlocked card. Make sur you don't put in a locked card!
Posted on Mar 27, 2008
Mode to set up push change(up) reset events yes. now try sim card
Posted on Jan 15, 2008
I don't have this brand of camera, but my experience has been that you may need to format or re-format your sd card.  ez
Posted on Oct 17, 2007
  • ezgrider Oct 17, 2007
    Or you may need another card.  ez
SOURCE:
Vivitar 508nhd wont work when SD card put in
Are you sure you have an SD card (2GB or smaller)? The 508 won't work with higher-capacity SDHC cards.
Jan 28, 2013 | Vivitar DVR 508HD Digital Video Recorder
When i put my sd card in my camera wont turn on
The PDR-3300 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use SD cards, 2GB and smaller.
May 13, 2012 | Toshiba PDR-3300 Digital Camera
My camera works without my microsd card in as soon as i put it in it wont do anything
Please try another sd card, if the problem persists the sd card slot /reader is faulty and causing the camera to lock up. If the problem goes away with another card, theres a problem with your old card.
Sep 06, 2011 | Cameras
I have a samsung digmax s600 i works fine without the sd card inserted but when i insert the sd card the camara wont turn on
Be sure you have a standard SD card to put into this camera, not a SDHC type.
You will be limited to a maximum of 2GB with SD, but it should work perfectly.
If not, check the SD card in a notebook or PC's cardreader and/or replace the
SD card with another one. If this does not work the SD card interface in the
camera may be defective.
Jun 09, 2011 | Samsung Digimax S600 Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
I have a Samsung S730 digital camera and like it very much. I have a 1GB SD memory card and it works great, but I want to purchase another memory card, but the only SELL 2GB SD cards is that ok to use in...
Hi
The Samsung S730 digital camera will work with 2Gb Secure Digital (SD) cards without an issue. If you want to go with a higher capacity card you can also use 4Gb and 8Gb SDHC cards.
Hope this helps
David
Dec 29, 2010 | Samsung Digimax S730 Digital Camera
Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Apr 22, 2009 | Canon PowerShot A400 Digital Camera
SD card - camera won't work
What SD Card are you using?
Need to make sure it is compatible with the camera.
Let me know and we will go from there.
Mar 27, 2008 | Vivitar ViviCam 3815 Digital Camera
SD card problem
Format the SD card using camera's format function. The SD card should work without a problem. BTW, what do you mean by Camera type: Qv-R41/Qv-R51? The camera should be either 41 or 51. 41 is 4MP and 51 is 5MP. Which camera do you have?
Sep 12, 2005 | Casio QV-R41 Digital Camera
Moultrie MFH-DGS-100V2 Digital Camera Logo
553 people viewed this question
Top Moultrie Cameras Experts
mitchp12
Level 1 Expert
 Henri P
Henri P
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
