Question about Maytag MAH8700A Front Load Washer
MAH8700 Water and Clothes stuck in washer.. HELP!!
Hello I purchased my washer 6/06 from homedepot. Washer has stopped with clothing and looks like water in it. Cannot open the door. I have plugged and unplugged it. I have put into service mode tne hit the chime button to at least open the door so I can get the clothes out(didnt work). When I do hit the chime button in service mode the number 559 comes up(not sure what that means?). If I try and start the washer it just hummms. Help please. Thanks
  • 447 Answers
Well its tough to tell exactly what is goin on.... when you are in service mode and press chime it displays how many cycles its done not a command to unlock the door (thats what you were attempting.right?)...559 cycles in a little over a year?? Thats a lot! you do like one a day every day??? Anyway aside from that it sounds like the pump is clogged with foreign objects. Its not easy to service the pump/sump on this new chassis neptune made by samsung. But after 559 cycles theres bound to be some stuff in there. If you feel lke servicing it yourself there is an axcess panel on the bottom and the back or take the whole front off the machine to service. You can try using a shop vac to suck the water out of the drain hose. The control should unlock the door when it sensed the water has drained or so it thinks.
Posted on Oct 07, 2007
Eliminate washer Odor
To clean washer add 1 cup of bleach while washer is being filled with hot water and run entire small cycle. DO NOT add clothes. This will help to eliminate odors and any stuck on dirt/ grime on the sides of the drum before washing clothes. I'm not an expert, just an experienced clothes washer for over 30 yrs. ,
on Oct 19, 2013 | Washing Machines
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Feb 02, 2009 | GE Energy Star WCVH6260F Front Load Washer
Maytag MAH8700 - NP error code - Door locked and won't open
I don't know if you are aware of this, but Maytag did a recall on this washer in March 2007 where there was a risk of water leaking into the control panel and shorting out the board. You can follow this link to see if your washer was affected based on the serial number:
Here is a link to your user manual to see if it offers any help. The only thing I saw was to use the Cycle Selector button to unlock the door.
I found this on the Maytag site:
Is the door locked and the Add A Garment or Add Clothes light off?
If the Add A Garment or Add Clothes light is off, then the washer door will unlock after the Pause/Off or Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
You could also try their customer service number to see if they have a script for this problem: 1-800-688-9900
The only other solution I can offer is to disassemble your washer if its that urgent and you can't get a repairman out there.
Jan 10, 2009 | Maytag MAH8700AWM Neptune Front Load...
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washer not draining water
check for defective lid switch or switch just out of adjustment.
Aug 24, 2008 | Washing Machines
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Maytag MAH8700A Front Load Washer Logo
173 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
