Question about Kirby Heritage II Vacuum
Kirby shampooer my shampooer used to work great, but now it won't pump the bubbles. I've replaced the filter, and filled it to the top line with water, but no bubbles. the only thing I can think is that the gasket is leaking.
  • 357 Answers
You are missing the wee round suds screen that fits over the small hole on the tank where the hose fits on. Without this screen it will not make foam.
Posted on Oct 16, 2007
SOURCE:
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby Ultimate G Series. I have misplaced (no, it's not lost...I have it somewhere) the manual. How do I use the upholstery attachment? Does it hook to the outlet on the shampoo tank?
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used.
Hope this helps!!!
Feb 14, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning my love seat
Vacuum the furniture thoroughly before shampooing. Once you've covered it with suds, pop the suds into the fabric using your hands...working the bubbles into any heavily soiled areas with a soft brush.
Dec 07, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Sentria
Your shampooer is not broken. (sorry Fanny)
You are missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box. Here's a link to my online Kirby shampooer instructions...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped!
Marci
Nov 05, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
159 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
