Question about Neff V4380X0 Front Load Washer / Dryer
Neff V4380X0 Front Load All-in-One Washer... error e06
My washer dryer keeps showing flashing light then e06 can any one tell me what this error is
  • Anonymous Mar 16, 2009
    same problem - e06 flashes. something to do with pump and drainage but cannot get into the machine to fix it - built into kitchen!
    Scholar:
  • 146 Answers
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Posted on Nov 04, 2007
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Sir i hav feced a e06 error in mp287 pixma plz solve the problem
Try this solution I found on a German site. Other sites I found did not even mention E06 as possible. Site is linked below, you can use GoogleTranslate to convert to your own language. Good luck!
Error E06 Canon MP287
The characteristics or signs:
  • Currently in turn on the printer does not print the worksheets.
  • ALARM indicator light lit In follow with lights flashing orange ink information.
  • LED indicators display appears on E06
How to Reset Error E06:
  • Press and hold the stop / reset until the standby light green and then release.
  • If the indicator light still flashing again, repeat again by pressing the stop / reset.
  • Finished
Dunia Printer
Jul 06, 2015 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Panel shows code error e06
tengo un error E06 tengo 2 meses que compre el equipo espero puedan ayudarme mi correo es nicolas82191@hotmail.com
Jan 03, 2013 | Lime Pro Equipment D7.3 Treadmill
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
Nov 21, 2011 | Bosch Washing Machines
I have a BOSCH washer/dryer WVTI2840 which keeps showing the error code E06. I have checked the pump and also had a new one fitted! The code still appears but now the machine will not spin on a rinse spin...
This error is indicating drain problem.You will have to manually drain the machine. E06 is a draining problem.
When you took the filter out did you check there was nothing jamming the impeller at the back?
Make sure the impeller turns ok. It should ping round in stages.
Also check were it drains to. If under a sink check the pipes there.
If after that its still not draining then its likely to be the pump which is faulty.If you have already replaced the pump then check the connection of pump to the hose.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | Washing Machines
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Light flashes green than a code E06 and E01 comes on than tv off
E01 is relay contacts failure on psu board in media box
Parksy HK
Now someone find E06
Nov 22, 2008 | Sharp Aquos PZ-43HV2U 43 in. Plasma...
Smeg wm16aaa error code e06 Can anybody help me on the above please
HEre's a link to Smeg's web site with all the error codes:
http://www.smeg-service.co.uk/support/index.php?a=1#1
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
G
Nov 08, 2008 | Smeg WM16AAA Front Load Washer
Neff V4380X0 Front Load Washer / Dryer Logo
1,800 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
