Our Bosch is 7 months old and has worked fine until this weekend. The water is not draining out. My husband has checked/cleaned both filters and has run a short test twice with no dishes to see if it would drain. Still full of water. What is our next step?
Comments:
May 04, 2009
- Thanks so much for your swift replies! Tomorrow morning Dan says he'll be checking all the lines. He installed it and is has lots of years experience fixing stuff, but hates plumbing! He wants to know, how do you check the blockage for the pump? This is the first time we've asked for help from this forum and you guys rock! I told him - we just need to go online! Thank you so much.
May 04, 2009
- P.S. It has a Studer air gap. We've had a previous dishwasher there that worked for 8 years without drainage problems.
It is under MF warranty through Bosh. you might want to have a tech out. First how is the drain-line routed? Into a air gap, johnston T, or disposer? If through the air-gap try cleaning that out. If through the disposer make sure you turn on the disposer & clear that out before starting the dishwasher. Bosh D/W sometimes require a stronger pump that what they are equipted with if you are on a septic sytem because they work off of gravity. Also the drain-line are sensitive as to being in the correct position. Is it possible they could have fallen or come unmounted. Also if you had it professionally installed, you should call the installer before tampering with the install. The installer should warranty the install for 1year.
Hi..
please check whether you have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed or not.
thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch 24 in. SHU66C02 /
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
How do I get ahold of user MRMark52, he has a solution to my dishwasher problem and sounds like he...
(More)
How do I get ahold of user MRMark52, he has a solution to my dishwasher problem and sounds like he would fix uit
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
