Question about T-Mobile MDA
T-Moblie MDA Dead
I bought a MDA off e-bay and it worked great for 3 months. Then, without warning, it just stopped working. I had it plugged in over night, battery wasn't depleated. Thinking the connection was bad I pushed pulled and wiggled until I broke the charging port off. I had it repaired, bought a new battery. Everything was fine for 3 days. Same problem. Plugged it in at night when it still had 80% full on the battery. Tried to turn it on in the morning and nothing. Completely dead! Any help will be appreciated.
  • Anonymous Feb 14, 2008
    I do have same problem as posted by 'Russell420 '. Any help?
    Perdesi
MDA's are BAD BAD BAD.  I'm now on my third phone for the exact same reason.  It just wouldn't turn on, charged or not.  I sent it back, stayed without a phone while they UPS it (because they don't manufacture the phone any more, so they send refurbished phones).  I am so sorry I switched from Verizon to T-mobile for this phone, I could scream.  They replace the phone with either another piece of junk MDA or the "Dash", which isn't at all close to the style of keyboard I bought the MDA for.
It's worth it to me to pay the $200 early termination fee to not have to pay $80/month for a phone, which really isn't a good phone at all, anyway.
Good luck, but it will do you no good with T-Mobile.  Sorry to be so negative, but after spending $400 for a phone and to have to replace it twice in 11 months, I have nothing positive to say.
Posted on Oct 15, 2007
I did the same thing, Blue Bay Electronics had a seven day warranty just long enough to fool me into giving a good report. Anyway look for a repair center and spend another 100.00. Good luck
Posted on Oct 08, 2007
A1200Y won't start
Dead CMOS battery does not cause the problem you are describing. More likely your southbridge chipset is defective on your motherboard. Replace the motherboard.
May 30, 2010 | HP Pavilion a1200y (EK457AV) PC Desktop
How do i unlock a t mobile mda compact v for free
how do i unlock my mda compact v moblie phone for free
Mar 27, 2010 | T-Mobile MDA Compact Smartphone
T-Mobile MDA Phone wont now charge or turn on
http://support.t-mobile.com/doc/tm22933.xml?related=y&Referring%20Related%20DocID%20List%20Index=5&navtypeid=6&pagetypeid=7&prevPageIndex=1
Mar 06, 2010 | T-Mobile MDA
Controller stopped working completely
Did you charge it ????
Will it charge when plugged in ??? (Blinking red light on controller??)
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
Charging prob
dear squeeze ur MDA pins with small flat screw driver or some type of needles..i hope this will work...
Mar 05, 2009 | T-Mobile MDA
MDA Vario died - HELP
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
Aug 16, 2008 | T-Mobile MDA Vario Smartphone
Garmin problems
try contacting garmin they are at garmin.com they should have a dealer near you or take it back to where you bought it they should exchange it no problem as long as you have the reciept hope this helps
Aug 15, 2008 | Garmin StreetPilot C330 GPS Receiver
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
I have an T-Mobile MDA. I haven't used it for over 6 months, went to charge it last night. plugged in the charger and the blue power light came on, went to menu screen. Left the MDA charging upon returning...
Your first bet is to remove the battery and hold down the power button for 10 seconds, then replace the battery and try to turn it on.
Sorry I'm not more familiar with the model of phone you're talking about but this has worked for my old PDA's when they won't power-cycle correctly.
Jun 27, 2008 | T-Mobile Computers & Internet
T-Mobile MDA Logo
202 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
