Question about Braun Tassimo Espresso Machine/Coffee Maker
Tassimo coffee machine doesn't brew automatically
Hi, I have a machine that is 10 months old. Just recently it will not go to auto. You need to hold down the button on manual to get it to make coffee. Please advise as to how I can correct this. Mindy
  • 2 more comments
  • Vincecwi Nov 27, 2007
    I'm having the same issue with an 11 month old machine. I have cleaned the window and still get the problem. Some times all 4 of the lights blink at once and I can't do anything.
  • Anonymous Dec 05, 2007
    I also have to hold down the manual button to brew coffee. Also need to know how to clean the inside the unit.
    [email protected]
  • Sionnach Dec 09, 2007
    Thanks, I've been having the same issue. I
    thought that I had cleaned the barcode reader, but perhaps not enough.
    I'll try it again.
    (apologies for putting this in "solutions" below :-/)
  • timmy60 Apr 28, 2008
    same gig, have to hold the button down to brew manually. cleaned and cleaned still sporadic auto operation. any way to change the bar code reader???
You have to clean the barcode-reader window. Very easy, just wipe it with a cloth. (It's the window just under the piercing unit thingy.)
Posted on Nov 10, 2007
Thanks, I've been having the same issue. I thought that I had cleaned the barcode reader, but perhaps not enough. I'll try it again.
Posted on Dec 09, 2007
SOURCE:
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
Jan 14, 2011 | Braun Tassimo Espresso Machine/Coffee...
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Hi,when my tassimo finishes filling the cup,it
For a Braun machine, unfortunately this is quite normal as it's part of the "purge" once it has finished brewing.
The new Bosch machines do not do this and finish their cycle with a steam purge instead.
Mar 25, 2010 | Braun Tassimo Espresso Machine/Coffee...
My Tasssimo coffee maker is 11 months old and isnt functioning.
Possibly all you need is to clean off the bar code reader window. It's right under where the bar code on the t-disc ends up. A little dried milk, etc., can cause your symptom.
Dec 18, 2009 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
474 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Norman Al-Anbar
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
