Question about Canon PowerShot A540 Digital Camera
Nothing happens when I press button to snap a picture
It happens on occasion, which is usually when I really need to use my camera. But when I go to take a picture, it doesn't click, just the flash-light lights up while I'm pressing the button, but thats it. Also, I can press really hard, and it may snap the picture, but thats only sometimes. Now, sometimes, the camera is fine and I can take a picture with no problem Strange, but I'm getting fusterated. Thanks!!!
  • Rachel Nelson
    Rachel Nelson Sep 13, 2008
    I went to take a picture with my camera one day and the button wasn't doing anything, it won't take pictures now... everything else on the camera is fine except when I push the "take picture" button, nothing happens. What should I do?
    Guru:
  • 1,894 Answers
Its not a great problem. but the thing is
1>>you have been handling it in quite rough manner
2>>the camera must be a very old aged one
3>>must be a faulty piece.
the buttoon has got loose. u wont get charged much for fixing this in service centre. so u its not a big deal to spend few bugs for camera.
Posted on Dec 22, 2007
The flash on my Panasonic DMC-FZ100 doesn't work, I've tried 'forced flash' and thats not working either?
Hello Ray, This is not something a user wants to attempt !!! The camera really needs to be repaired by a tech. You will do more harm than good by trying to fix it yourself and will cost even more if you damage something.
Best Regards, Russell
Jan 22, 2013 | Panasonic Lumix DMC-FZ100 Digital Camera
My Olympus x-42 doesn't take a picture. View from monitor is perfect but when I take a picture, all there is is a white screen
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value.
Click on or copy and paste the link into your browser... CCD Sensor Problems
In this link, other owners with this problem obtain certain commets:support/canon_fs100_fully
Hope this helps.
Aug 15, 2012 | Olympus X-42 Digital Camera
The flash of my sx30 doesn't work, when i open the flash it was detected that the flash is open but the the problem is when i'm going to shoot even i press my shutter it doesn't take any...
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
Hiya, Just a small matter, but on my Youtube the video works well; but its just the picture cannot run smoothly, it has to constantly jump. This doesn't happen all the time, just on occasions, but...
This will be your internet connection. You should reset the modem and router. If that doesn't work try relocating the router for a better wireless signal.
Best of luck!!
May 27, 2011 | YouTube Videos
Internal Flash not working-Canon Eos 40D
I've had this happen to me too and I've been researching about it. Aparantly it happens because the camera still think the external flash is attached. If you go into the menu and under flash control, try ot enter the settings for built in flash. If this is the problem it will tell you here that the external flash is still attached. From what I have read to far, I'm not sure how to fix it. I would reccomend taking it in somehwere. I dont htink its a hard problem to fix.
Dec 06, 2008 | Canon EOS 40D Digital Camera
After reseting the dsc w50, becouse of e .91.01., flash is not working
hi worked for me , remove battery take apart, discarge the capistor i think 320 volt DO NOT SHORT THE CAP !!!when dead voltage on cap ,turn on reset all camera and try good luck
Aug 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
The flash on my camera will not go off, it shows the light in the back ready, but nothing happens to help light up the picture
If your using the hot shoe with an external flash, three things could've happened: battery power in your camera is too low to fire the flash; or check the menu/settings/flash - ext flash settings may not have been chosen by the camera, but you may need to set it first manually; or your hot shoe is not a hot one, but your flash needs to be plugged into a PC outlet on the side of your camera. One last thing - test fire your flash and make sure it works to rule out the camera. There have been occasions where the ready light works on the flash, but it won't fire even after being plugged in. This problem was found to be a loose soldered wire in the flash foot. Another time it wound up to be the flashtube. Hope this helps.
Aug 01, 2008 | Cameras
Casio Exilim EX-Z850 Red Light Flashing
I have the same problem but could not find any solution as yet. My work around is to switch of the flash and shoot with manual controls - of course that only works well when using a tripod or someting similar. I think it is a bug with the flash loader wich seems not to give the go for shooting until flash preload is finished. If anybody has a real solution I'd be happy to read. cheers e
Sep 29, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Dark images
probably the flash system got broken, or the lens got damaged. and doesn´t mesure the light
Jan 21, 2007 | Samsung Digimax 301 Digital Camera
Very long shutter release delay
This is weird, usually shutter delays are caused because camera is trying to focus first, it really shouldn't happen after pre-focus. do you have a manual focus mode? if you do, try it and see if it works. if you dont, I would still suspect it some kind of focusing problem, but unfortunalty i have no idea how you can fix it yourself.
Mar 10, 2006 | Canon EOS-20D Digital Camera with 17-85mm...
Canon PowerShot A540 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
