Question about Euro-Pro Steam Generator EP8001 Iron
EP8001 Steam generator.
The steam hose at the base of the iron is kincked and does nor allow frww flow of steam. I would like to open the iron and fix this by cutting off the damaged piece of hose. unfortunately the nuts/screws at the base of the iron are of a peculiar shape and I do not know what tool to use to open the plate. any advice?
I have recieved the Euro -Pro Steam Generator EP8001 as a gift but did not recieve the instruction manual where can I find a copy of the instuction Manual on line.
Thank you Sandra
Posted on Jun 13, 2008
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Posted on Dec 14, 2007
I have SGR pro k121 steam is not working
-Make sure dial or slide control switch to the correct position.
-Make sure there is water in the reservoir.
Good luck
Mai
Jun 06, 2016 | Euro-Pro Steam Generator EP8001 Iron
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
Steam generator iron beebs when button pressed but no steam green flashing light on aswel
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 21, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro ep8001 steam iron
I found the fix myself.
I found a switch without the light and it works
Sep 08, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
349 people viewed this question
Top Euro-Pro Irons Experts
Sheldon Dedek
Bruce Showalter
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
