Question about Compaq EVO D5S SFF Refurbished Desktop Computer
Compaq 510s sff. Graphics Card
Just bought a sff compaq and its got no graphics card installed. i tried an AGP (geforce FX 5200 128mb). That didn't work at all. nothing happened at start up. do i have to get a PCI graphics card or are there some AGP cards that work? if so do you know which ones? Not much room inside the box so a PCI card may not have room. Thanks in advance Michael
  • mike wright Oct 10, 2007
    just turned off pci in the bios. worked great. thank you
    Problem Solver:
  • 12 Answers
Hi Mikey You need to go to your bios setting and change your graphic adaptor from PCI/.. to AGP 1- turn your computer off (Shut Down) 2- keep press and release "delete" key on your keyboard while turning your computer on untill you go to bios (normally blue screen) 3-find your desplay/graphic or anything that is related to graphic. 4- Change it to AGP Now it should work but if it didn't work: 1- Faulty Display (Monitor) 2- Not compatible graphic card(rearly) 3- loose or damaged cables 4- Damaged Motherboard please let me know of your progress Kind Regards
Posted on Oct 09, 2007
SOURCE:
I have a nvidia geforce fx 5500 graphics card which says it has 256mb available memory,and it says total video memory 256 mb,shared video memory n/a ,shared video memory n/a, and when i try to play age of...
You will need to install the latest drivers for this card. Go to the Nvidia website and select the relevant options from the drop down menus.
Product Type: GeForce
Product Series: GeForce 5 FX Series
Product: GeForce FX 5500
Operating System: The operating system you are using
Language: English (US)
Then click search
It will then take you to the download page.
If this dowsn't work then make sure you have connected your monitor to the FX 5500 card and not to onboard graphics.
Jan 14, 2011 | Palit Microsystems GeForce FX5500, (256...
HP DL 330 advantage of AGP graphic cards
the larger the size of the graphics card the better quality your gaming and entertainment programs will come out. however the graphics card cant always help if your monitor doesn't have a good enough display (480, 720, 1080p)
Jul 13, 2010 | HP GeForce FX 5200, (128 MB) AGP Graphic...
HP GeForce FX 5200, AGP Graphic Card fit the slot in my HP Pavilion Slimline s3620f
No this card won't work in an 'HP Pav. Slimline s3620f" The specs from HP say it has one open PCI-E slot that is used for graphics cards.
Jul 09, 2010 | HP GeForce FX 5200, (128 MB) AGP Graphic...
After installing geforce fx5500 ddr 128 agp I get a black screen
Switch to the graphics card in your bios instead of your on board graphics.
Feb 08, 2010 | PNY VERTO GEFORCE FX 5500 128MB DDR AGP...
Graphics card
Desktop Casings are lower enough that can't be closed when inserting Cards like your Graphics card. Change your desktop casing to Tower Casing so you can freely install your Graphics card to the graphics card of your motherboard.
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
Can you use a 128bit agp graphics card on a 32bit agp motherboard
yes install the drivers then under the device mgr disable the onboard video adaptor
Dec 19, 2008 | XFX GeForce FX 5200, Graphic Card
HP Compaq d530 SFF PC Desktop Problem - Graphics card: Updgrade
Try this site:
http://www.geeks.com/products.asp?cat=VCD
The ATI Radeon HD 2400 256MB PCI-Express VCD w/TV-Out DVI seems to me to be what you are looking for..
Good Luck!
Apr 18, 2008 | HP Compaq d530 SFF PC Desktop
Fx 5200 geforce graphic card
You did not mention if the board your running has an integrated video card on it. If it does & you have added the FX 5200 AGP you need to make a change in your bios. Set the bios to see AGP. Re-check the insertion of the AGP card. Remove the video card. Use a strong flash light & look into the AGP slot. Use canned air & blow out the AGP slot. Re-seat the video card evenly into the AGP slot. Try again.
Feb 13, 2008 | XFX GeForce FX 5200, Graphic Card
GeForce FX 5500-picture flickers
assuming you have set your agp slot in the cmos settings to the primary graphics controller and already had the agp graphics slot driver installed for the motherboard, try using a driver from the nvidia web site if you are having trouble with the driver that came on the cd. Use the VGA onboard graphics if you have any or fit your old card and click on the link below for XP Drivers http://www.nvidia.com/object/winxp_2k_93.71.html If you still have problems then you will have to try an ATI graphics card as it just may not be compatable with your make of motherboard
May 08, 2007 | XFX GeForce FX 5200 Graphic Card
Computers & Internet Logo
272 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
