FixYa.com
Tags:
Harley Davidson 426290 AM/FM Radio
HD 2001 UCI Radio (by 2 users)
posted by Reg2007 on Oct 07, 2007
I have a 2001 HD Ultra Classic with a stock radio.
On occation and now more frequently that before, the radio will go into a Seek Mode and activation of any control button will not stop the seeking. I also loose the ability to turn the radio off.
After a period of time the radio may go back to a state of which all is operating normal.
Turning the ignition switch off and on may but does not always clear the problem and if it does the problem may return very quickly.
I am looking for advice as to what area is or could be failing. Is it likely that one of the control switches has failed or is it more likely that the malfunction is in the radio itself.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 10, 2008
Have a 2006 UCI and the radio worked fine until battery discharged and the radio won't come on now. checked all fuses and all are OK. I'm not sure but it might need to enter a code to activate the radio again. What to Do?
Best Solution
posted on Feb 24, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
my bike did the same thing.sent the radio in for repair,they sent it back and said it had no problems,it worked great.after hrs of debate i decided to put it back in the bike,it still did not work,so started taking it out again,the wrench i was using touched the frame and the radio came on,every time it ground the radio to the frame.i put an external ground wire from the radio to the frame,its worked ever since.and i spent 300 bucks at hd,and fixed it for nothing myself
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Personal Radios problems?
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
Personal Radios
Audiovox AXR48- find manual?
I can't find a manual for my... Answer This...
Personal Radios
Need replacement earpads for...
Hi, folks....My radio is a few... Answer This...
02 Ultra radio switches from cb...
My 02 Ultra Classic stock radio... Answer This...
2002 harley davidson am-fm...
The battery on my electra-glide... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
