Scanner my computer wont recognise my scanner ive installed it but it keeps coming up turn on scanner and ensure leads are connected properly which they are
  • Anonymous Nov 26, 2007
    the computer is not reconignizing the scanner
  • 38 Answers
Usually this is a problem with old (parrallel port ) H.P Scanners. Shut down your PC, remoce power of the scanner, remove the data cable of the scanner both at PC as well as at scanner end. Reboot the PC. reconnect the data cable and then the power cable ofthe scanner. Try using it. If you have win98, it should work now. If Win XP_P, reboot your PC, it should work. If the problem persists, try re-installing the drivers.
Posted on Oct 08, 2007
My packard bell laptop will not recognise my visioneer 4800 scanner, although it has done previously
If this is a USB connection, and you have checked that the drivers are installed, scanners are weird in that they require you to ensure it is plugged into the same USB port as it was installed on
May 10, 2011 | Visioneer 4800 Flatbed Scanner
USB nightmare, okay frustratingly even though everyone else uses one with ease ive plugged mine in i see its working, ive been advised to goto my computer in menu, to locate device from here, than there is...
You should first ensure that the"fly lead" is connected between the monitor and the computer otherwise you wont see anything at all.
Not all monitors have USB ports and the implementation is not always the best.
I would start by formatting a usb drive and ensure it is formatted to FAT or FAT 32 (most offer that in the drop down format menu) do the format on a known computer not monitor.
Once done plug that into the monitor to see if it shows.
If not come back and give any additional information to this post.
Again check you have the fly lead in first.
Bob
Mar 17, 2011 | Likom Futura LD7 17" CRT Monitor
Computer wont recognise new canon pixma mp250 printer
If you have more than one USB hubs try connecting through the other hub. May be this hub is not functioning. It happened with me once.
Apr 21, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
Sony K610i Will not sync with my computer
Please ensure that all drivers are installed. Check in device manager.
Right click on my computer and select properties. Then select the hardware tab and device manager in that section. If any drivers are not installed properly they will appear with a yellow exclamation mark. Reinstall these.
If all drivers are installed correctly check the contacts on the phone as sometimes the tend to get dirty and block the signal. also check if cable is faulty.
May 25, 2009 | Sony Ericsson K610i Cellular Phone
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
May 07, 2009 | Office Equipment & Supplies
Trouble uploading photos from my camera.
You may not have the software installed on your computer or it's not installed properly.
First tru plugging in your camera using the USB and turning the camera on (press the arrow buttun for about a second). The FinePixViiewer should open.
Apr 30, 2009 | Fuji Finepix Z20fd Digital Camera
SONY NW-A3000
Bad news - if you tried multiple pc's and it still failed, then your player is done.
Make sure you:
reset the player
upgraded the firmware
used the recovery tool
called Sony to be sure
last ditch effort:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Buh-bye!
-Tha Mp3 Doctor
Dec 10, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Computer Wont Recognize Camera
if u r using xp try this option ..control panel> printers and hardware >scanners and cameras..and try installing the camera from dere keeping it connected...if this doesnt wrk ..chk if ur camera is in the 'mass storage memory' mode..can be found easily in the menu settings..and then connect....if still not recognised...search for the drivers on net
Sep 18, 2007 | Sakar 57482 Digital Camera
731 people viewed this question
k24674
Marvin
Marvin
