SOURCE: DVD not copying
It would be best to post the error message here verbatim so we can see exactly what it says.
By far most burning errors can be overcome by just slowing down your burn speed.
If you are not in a super urgent hurry, burn DVDs at 4x or lower, even 1x.
You'll get less errors, and the archival qualities of the disk itself will be much greater (ie, the data on the disk will last longer).
Ask a "knowledgable" photographer about the benefits of longer exposures with film photography - the light penetrates that little deeper giving greater depth in tonal range and detail and it's exactly the same with the laser light on 'burning' data to a disk.
Slow down.
**.The best way to acknowledge contribution is to rate it's relevance.**
SOURCE: Roxio help
download the latest version of roxio viz roxio creator 10 (if you dont have it) .. disc copier is available in that..
SOURCE: Problem burning ISO image to disc in Roxio... dll?
I would suggest following the instructions found on Roxio's knowledge base
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000008GN&PARAMS=
SOURCE: When you try to burn a disc in Roxio MYDVD 9 or
Unistall the software and reinstall it agian. and also download the software ccleaner which will delete all the unwanted files from your system. and also run msconfog command from run and uncheck all the startup items
http://www.ccleaner.com/
Please feel free to contact me at my email address [email protected],
Skype Id amitbhardwaj04
Regards
Amit Bhardwaj
We connect to your computer over the Internet to quickly repair your PC. Professional support with certified techs to make your computer run like new again.
SOURCE: DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
