Question about Bosch 24 in. SHU53 Built-in Dishwasher
Cycle continues to 27 min then....
The wash cycles down to 27 minutes then runs continuously until I manually turn it off. The counter never advaces to 0. Same is true in econo mode but it cycles down to 19 minutes. Rince and hold seem to work OK. It fills with water and drains so there are no clogged lines. Is this something that I can fix with ordering a new part and if so who sells the parts? Thanks in advance! PC
  • 909 Answers
Re: Cycle continues to 27 min then....
I suggest you check the heating element for open circuit and or check the thermostat for open circuit(timer wont proceed if heat is not available). if both ok, your electronic control or timer is faulty. replace.
Posted on Oct 08, 2007
0 characters
3 Points
Gu 120 es
there is a "smartclean" sensor that measures dissolved solids in the water in an attempt to shorten the washing cycle. however if the dishes have much food left on them, then the washer will continue to run untill it gets a "clean" reading, or it reaches the max run time (180 minutes). all energy star dishwasher require the dishes to be throughly rinsed before washing in the machine. trust me, i know how counterproductive this is.
Sep 26, 2013 | Whirlpool Dishwashers
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a Bosch SHE46CO dishwasher that runs too long. It adds an extra 37 min to the normal wash cycle. It counts down correctly until about 50 min then it adds the 37 min. Also when it get to 1 min it...
it can be the software or anly have a much colder water and it needed a longer time to heat for washing and rinsing. also a heater is damaged and the dishwaser runing at the half capacyty. so long!
Feb 23, 2010 | Dishwashers
Dishwasher will not run through its cycle
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Mar 26, 2009 | Dishwashers
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpool Quiet Partner Doesn't finish cycle
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
Kenmore model 665 dishwasher
the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try for the part number and price.installing the timer isnt that difficult.
Jan 05, 2008 | Kenmore 24 in. 16304 Built-in Dishwasher
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
128 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
