Question about Toshiba Satellite M35X-S161 Notebook
Cannot boot. Power indicators lights up, fan swirls, but no activity
First, I had problem with the DCIN power Jack. when I switch on the laptop, I had to shake the DCIN jack for the laptop to boot. Now, shaking does not help. I have removed the DCIN jack and resoldered it but still no solution. When powered, fan starts up for a while and stops. Lights are on but laptop does not even seem to read the cmos.
  • Anonymous Dec 07, 2007
    I have same problem ı need help ASAP ...
  • Anonymous Mar 28, 2014
    ive been struggling for a while and assumed it was the charger as that was getting old but having brought a new one and still nothing happens I suspect its the DCIN part of the computer with the problem..i now cant use the laptop as its dead and will not charge so I am looking for help on how to fix it and what to do..
I have the same problem with my Toshiba.  Called Toshiba tech support and they said to send the computer in, as they have extended the warrany until 11/6/2007.  Their thech support number is 800.867.4422
Posted on Oct 23, 2007
This sounds like an issue of processor overheating.  While you may have initially dealt with a broken connection between the DC jack and motherboard the shaking of the unit could have caused separation or poor contact between the processor and its point of contact to the cooling fan thereby causing the processor to overheat immediately after startup.
Posted on Oct 22, 2007
  • 32 Answers
Call Toshiba immediately. Ask to ship the computer to the depot including the AC adapter, to determine if problem lies on the AC of th DC in jack. M35X has an extended warranty until 11-7-2007.
Posted on Oct 15, 2007
SOURCE:
My asus x54h sx270v wont charge i think its the DCIN part
you can check if the dc power jack if loose or not by inserting the charger and try to feel if it loose or not, if yes, probably you need to some replacement.
thanks
Mar 28, 2014 | ASUS Computers & Internet
Acer 5315-2315 Laptop, No Power or Power On LED Light
It happens when system gets heated and then afterwards it hang. So it is a problem with your system power supply. You need to change it.
Jul 23, 2013 | Computers & Internet
Switch on Failure
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 11, 2012 | Computers & Internet
Packard Bell L4 just the HD lamp lights and Power Light.No activity at all though.
I'am afraid this is very bad news, the motherboard is far to gone to rescue, but lets try something, remove main battery and the power supply from the laptop, press and hold power for 2 minutes, at the end of that time put everything back in place and power up. If this fails motherboard only option.
May 03, 2012 | Packard Bell Computers & Internet
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
Apr 20, 2012 | Sony Computers & Internet
My samsung r519 wont turn on. when i press the on button i here the fan going, yet the screen stay's black and only the power light comes on. what could the problem be?
Does the fan stay running? if it does! it is probably a motherboard issue, if the fan is working correctly it should wind down, and if the hard drive is working "hard drive light will flicker" hook a external monitor to the video output on the back of your laptop if you see windows boots up then it would indicate laptop screen problem, but if the fan and the power light are the only activity then the motherboard is the problem.
Dec 22, 2010 | Computers & Internet
I have a Model M40X that only turns on power light after switching on then starts the fan for 4 seconds hd and dvd lights just flash once then nothing no boot screen just the power light. 1 out of 25...
There are many things that can cause this type of symptom.
Is it failing on battery only? May need a new battery.
is it failing when plugged into the power adapter?
The adapter input jack will fail over time and need to be replaced.
There is considerable mechanical stress on this part, and It will fail where the jack is soldered to the circuit board.
Internal circuits can fail. Maybe a new laptop will be cheaper than repairing this one.
Oct 05, 2017 | Toshiba (K000002020) Motherboard
No post and no display
Do you have any indicator light activity at all?
If so, then try hooking up an external monitor.
If it shows display on the screen this would point to video issues (CCFL tube, Inverter, video chip, one or a combination of.)
There is also a key combination to switch between internal display and external monitor. Usually FN key + (little monitor symbol on one of the upper function keys)
If you dont have any indicator light activity then;
Things i would try first.
  1. Check the power adapter for power. (if you have a voltmeter this would be the easiest way) if not, try switching to another outlet
  2. Check your DC power jack to see if there is any freeplay or damage to it.
  3. If both these check out, then i would unplug dc power adapter from laptop, remove battery, and let the laptop sit for a few minutes. Then hold down the power button for 10-15 seconds. Plug in the DC power jack but dont place the battery back in yet.
  4. Try powering up. if no go, then plug the DC power jack back in and try powering up again.
If this still doesnt work, and your DC adapter voltage checks good and your DC power jack isnt loose, i would suspect either a charging circuit issue or deeper motherboard related issues.
Hope this helps
Feb 15, 2010 | Gateway MX6750 PC Notebook
Hello. when i plug in my hp dv5220us laptop it sounds like the fans running all cenyer lights on but power button will not turn on. same with battery
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | HP Pavilion Dv5220us Notebook
Toshiba Satellite M35X-S161 Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
